跳转到主内容
Huawei P9 Earpiece Speaker Replacement
你所需要的
  1. Huawei P9 Earpiece Speaker Replacement, Back Cover: 步骤 1 中的图像 1,3 Huawei P9 Earpiece Speaker Replacement, Back Cover: 步骤 1 中的图像 2,3 Huawei P9 Earpiece Speaker Replacement, Back Cover: 步骤 1 中的图像 3,3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Earpiece Speaker Replacement: 步骤 2 中的图像 1,2 Huawei P9 Earpiece Speaker Replacement: 步骤 2 中的图像 2,2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Earpiece Speaker Replacement, Fingerprint sensor: 步骤 3 中的图像 1,2 Huawei P9 Earpiece Speaker Replacement, Fingerprint sensor: 步骤 3 中的图像 2,2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Earpiece Speaker Replacement, Earpiece Speaker: 步骤 4 中的图像 1,3 Huawei P9 Earpiece Speaker Replacement, Earpiece Speaker: 步骤 4 中的图像 2,3 Huawei P9 Earpiece Speaker Replacement, Earpiece Speaker: 步骤 4 中的图像 3,3
    • Loosen the seven Phillips #00 screws on the motherboard.
    • On one of them might be a sticker. Remove it.
    • Unplug the antenna cable.
    • The metal plate covering the battery connector has two little hooks on each side. Use a tweezer to free them and unhinge the plate towards the top.
  5. Huawei P9 Earpiece Speaker Replacement: 步骤 5 中的图像 1,2 Huawei P9 Earpiece Speaker Replacement: 步骤 5 中的图像 2,2
    • Disconnect the volume button cable and the display cable …
  6. Huawei P9 Earpiece Speaker Replacement: 步骤 6 中的图像 1,2 Huawei P9 Earpiece Speaker Replacement: 步骤 6 中的图像 2,2
    • … as well as the battery connector and the cable running to the daughter board.
  7. Huawei P9 Earpiece Speaker Replacement: 步骤 7 中的图像 1,2 Huawei P9 Earpiece Speaker Replacement: 步骤 7 中的图像 2,2
    • Now you can lift out the motherboard to access the earpiece speaker.
    • Be careful with both cameras since they are still connected to the motherboard.
    • The earpiece speaker ist fixed with an adhesive foam gasket.
结论
Dominik Schnabelrauch
于11/23/16注册
209,996 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,895篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 2,468
