First switch off your phone and remove the SIM card tray.
Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
Loosen the seven Phillips #00 screws on the motherboard.
Unplug the antenna cable.
The metal plate covering the battery connector has two little hooks on each side. Use a tweezer to free them and unhinge the plate towards the top.
即将完成!
结论
