跳转到主内容
Huawei P9 Charging Board Replacement
你所需要的
  1. Huawei P9 Charging Board Replacement, Back Cover: 步骤 1 中的图像 1,3 Huawei P9 Charging Board Replacement, Back Cover: 步骤 1 中的图像 2,3 Huawei P9 Charging Board Replacement, Back Cover: 步骤 1 中的图像 3,3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Charging Board Replacement: 步骤 2 中的图像 1,2 Huawei P9 Charging Board Replacement: 步骤 2 中的图像 2,2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Charging Board Replacement, Fingerprint sensor: 步骤 3 中的图像 1,2 Huawei P9 Charging Board Replacement, Fingerprint sensor: 步骤 3 中的图像 2,2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Charging Board Replacement, lower section: 步骤 4 中的图像 1,3 Huawei P9 Charging Board Replacement, lower section: 步骤 4 中的图像 2,3 Huawei P9 Charging Board Replacement, lower section: 步骤 4 中的图像 3,3
    • Undo the three Phillips #00 screws.
    • Disconnect the loudspeaker flex connector.
    • Carefully remove the metal bracket.
    • Mind the adhesive underneath that might stick to the headphone connector.
  5. Huawei P9 Charging Board Replacement: 步骤 5 中的图像 1,3 Huawei P9 Charging Board Replacement: 步骤 5 中的图像 2,3 Huawei P9 Charging Board Replacement: 步骤 5 中的图像 3,3
    • Disconnect the motherboard flex cable and the antenna cable.
    • Unplug the headphone jack connector.
  6. Huawei P9 Charging Board Replacement, Charging Board: 步骤 6 中的图像 1,1
    • Now you can easily remove the charging board.
结论
8等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
209,996 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,895篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 7,184
