跳转到主内容
Huawei P9 Back Cover
你所需要的
  1. Huawei P9 Back Cover, Back Cover: 步骤 1 中的图像 1,3 Huawei P9 Back Cover, Back Cover: 步骤 1 中的图像 2,3 Huawei P9 Back Cover, Back Cover: 步骤 1 中的图像 3,3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Back Cover: 步骤 2 中的图像 1,2 Huawei P9 Back Cover: 步骤 2 中的图像 2,2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Back Cover, Fingerprint sensor: 步骤 3 中的图像 1,2 Huawei P9 Back Cover, Fingerprint sensor: 步骤 3 中的图像 2,2
    • Disconnect the fingerprint sensor using a spudger.
结论
7等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
119,191 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,092篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 8,998
