跳转到主内容
Huawei P8 Lite Camera Replacement
你所需要的
  1. Huawei P8 Lite Camera Replacement, Camera: 步骤 1 中的图像 1,1
    • Insert the SIM card eject tool into the small circular slots.
    • Apply slight pressure to pop the SIM card out, and remove it.
  2. Huawei P8 Lite Camera Replacement: 步骤 2 中的图像 1,1
    • With your finger nails, spudger or other gentle tools, remove the back cover by wedging into the space and popping the edge free.
  3. Huawei P8 Lite Camera Replacement: 步骤 3 中的图像 1,1
    • Remove three screws using a Phillips #000 screwdriver.
    • Remove four screws using a T5 Torx screwdriver.
  4. Huawei P8 Lite Camera Replacement: 步骤 4 中的图像 1,1
    • Using your fingers, carefully unlatch and remove the connectors attached to the motherboard.
  5. Huawei P8 Lite Camera Replacement: 步骤 5 中的图像 1,1
    • With your fingers, gently remove the motherboard and set aside.
  6. Huawei P8 Lite Camera Replacement: 步骤 6 中的图像 1,1
    • With the spudger tool, gently lift the front camera from the motherboard.
  7. Huawei P8 Lite Camera Replacement: 步骤 7 中的图像 1,2 Huawei P8 Lite Camera Replacement: 步骤 7 中的图像 2,2
    • Use the spudger to remove the rear camera.
结论
3等其他人完成本指南。
Brayden Mann
于02/05/16注册
639 声望
创作了4篇指南
团队
Metro State, Team 1-2, Carpenter Spring 2016 Metro State, Team 1-2, Carpenter Spring 2016 的会员
MSU-CARPENTER-S16S1G2
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 1,446
