简介
Use this guide to remove or replace the interconnect cable including the charging port in the Huawei P20 Pro.
Opening the Huawei P20 Pro will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will lose its water-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
你所需要的
Switch off your phone.
Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
Press a suction cup onto the rear glass close to the bottom edge of the phone.
Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
if the back cover is not broken, i’d suggest NOT to use an opening pick as if the phone was not heated enough, you may crack the glass on the edges. better use the iPlastix, it is thinner and less stressful for the glass.
I have to agree that is is much easier to start opening from the side. Do read the rest of the guide though, to make sure you won’t hit something when opening it from the side.
Jacob Cain - 回复
Remove the rear glass.
Das mit den Klebstreifen funktioniert nicht. Ich habe die Tube E6000 in die Dichtungen eingeklebt und so das Smartphone wieder zusammengesetzt.
Remove the motherboard cover.
Porque cuando desconectas el nfc no vuelve a funcionar?
a teraz to zopakuj po vychodňarsky
Use the flat end of a spudger to pry up and disconnect the battery flex cable.
Das Flachbandkabel kann einen Zentimeter zu lange sein. Ich musste ihn 2 mal falten, um beim Einbau die Steckerbuchse wieder zu treffen.
12等其他人完成本指南。
4条评论
Hallo ich habe alles nach der Anleitung gemacht. Nun geht der Connector wieder, aber ich habe das Problem, das ich innerhalb von Gebäuden kein Netz mehr habe. Außerhalb von Gebäuden kein Problem. Was kann ich tun? Das Antennenkabel weißt auf den ersten Blick keine Beschädigungen auf…
hola, y.. ¿cuales tipos de pegamentos recomiendan para volver a pegar la tapa trasera? Use Poxiran( cemento de contacto) pero no se adhiere bien al plastico
Hi, you can use double sided adhesive tape like this one or even pre-cut adhesive for the rear case if you get one for your device on the internet. Poxi-ran could work too after removing old adhesive and if applied carefully only on those areas where there was adhesive.
dear friend hi. thanks for your perfect explanation but in my case, i wasn’t so able to fix my Huawei P20 charging socket and battery replacement that i had to do. The problem that i have is that the phone now is not charging. when i connect the cable to charge the phone the first 2 sec looks like is charging but after that is stopped. One more problem that i have is when the phone is into the charger and you turn it of is doing a restart by itself. The speaker is working and also the data transfer. Have you ever seen this kind o issue before?
Ich hatte keinen iOpener. Daher hab ich das P20 Pro für ein paar Minuten auf eine Wärmflasche gelegt. Die Klebeschicht konnte relativ schnell gelöst werden.
David T. - 回复
