简介
使用本指南更换华为 Mate 9 显示屏。
你所需要的
断开天线电缆并小心地将其取下。
拆下将子板固定到位的四个 Phillips#00 十字螺丝。
Die kleine Schraube links oben sollte auch gelöst werden, sonst geht der Lautsprecher nich raus ;-)
Das ist natürlich richtig und wurde korrigiert!
The #00 screwes are five! One is in the bottom-left side!
That’s right! I corrected that!
请按逆序重新组装设备。请在必要时重新涂抹粘合剂。
13等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7条评论
I have issue with the assembly process. Im adding 3m adhesive tape that I received with replacement screen, and everything looks fine. But after inserting phone into aluminium back the screen pop out int the middle of frame, delaminating and showing backlight of lcd. The adhesive just not hold it enough..
The iFlex isn’t listed in the tools.
Check, now it is listed. Thanks for the note.
it’s almost impossible to remove the battery without damaging it!
My advice to you is to buy the LCD screen with the battery included.
Removal of battery absolutely / highly recomended, Display parts group needs to be heated to remove adhesive, and believe me - there is lots of it, either by i-opener or other means.
Also yes, battery can't be removed without damage, to much adhesive on to much contact area of battery.
