跳转到主内容
Huawei M750 Charging Port Replacement
你所需要的
  1. Huawei M750 Charging Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
  2. Huawei M750 Charging Port Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by levering the battery out, using the cut just below the camera.
  3. Huawei M750 Charging Port Replacement, Back Panel: 步骤 3 中的图像 1,1
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
  4. Huawei M750 Charging Port Replacement: 步骤 4 中的图像 1,2 Huawei M750 Charging Port Replacement: 步骤 4 中的图像 2,2
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
  5. Huawei M750 Charging Port Replacement: 步骤 5 中的图像 1,2 Huawei M750 Charging Port Replacement: 步骤 5 中的图像 2,2
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
  6. Huawei M750 Charging Port Replacement, Charging Port: 步骤 6 中的图像 1,2 Huawei M750 Charging Port Replacement, Charging Port: 步骤 6 中的图像 2,2
    • Using the opening tool, start prying out the motherboard from the front panel along the border.
    • When the motherboard seems separated from the front panel, pull it outwards.
  7. Huawei M750 Charging Port Replacement: 步骤 7 中的图像 1,2 Huawei M750 Charging Port Replacement: 步骤 7 中的图像 2,2
    • The charging port is soldered to the motherboard, use this guide to do the replacement.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 260
