跳转到主内容
Huawei Honor 9 Front Facing Camera Replacement
你所需要的
  1. Huawei Honor 9 Front Facing Camera Replacement, Remove the Rear Glass: 步骤 1 中的图像 1,1
    • Switch off your phone.
    • Heat an iOpener and apply it to the back of the phone for around two minutes. This will help soften the adhesive securing the rear glass.
    • You might need to reheat and reapply the iOpener several times during the rear glass removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Huawei Honor 9 Front Facing Camera Replacement: 步骤 2 中的图像 1,2 Huawei Honor 9 Front Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction cup to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • Don't attempt to insert a pick between the back glass and the frame before creating a gap. The glass is covered with foil from the inside, and by not creating a gap, you risk inserting the pick between the glass and the foil instead, which would permanently damage the foil and ruin the solid color of the back panel.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
  3. Huawei Honor 9 Front Facing Camera Replacement: 步骤 3 中的图像 1,3 Huawei Honor 9 Front Facing Camera Replacement: 步骤 3 中的图像 2,3 Huawei Honor 9 Front Facing Camera Replacement: 步骤 3 中的图像 3,3
    • Slide the opening pick to the bottom right corner.
    • Insert a second opening pick and slide it to the bottom left corner.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei Honor 9 Front Facing Camera Replacement: 步骤 4 中的图像 1,3 Huawei Honor 9 Front Facing Camera Replacement: 步骤 4 中的图像 2,3 Huawei Honor 9 Front Facing Camera Replacement: 步骤 4 中的图像 3,3
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the Huawei Honor 9 to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei Honor 9 Front Facing Camera Replacement: 步骤 5 中的图像 1,2 Huawei Honor 9 Front Facing Camera Replacement: 步骤 5 中的图像 2,2
    • If the adhesive gets hard to cut it is likely too cold. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei Honor 9 Front Facing Camera Replacement: 步骤 6 中的图像 1,2 Huawei Honor 9 Front Facing Camera Replacement: 步骤 6 中的图像 2,2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei Honor 9 Front Facing Camera Replacement: 步骤 7 中的图像 1,2 Huawei Honor 9 Front Facing Camera Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $5.99
    • Carefully lift the rear glass and remove it.
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  8. Huawei Honor 9 Front Facing Camera Replacement, Remove the Motherboard Shield: 步骤 8 中的图像 1,1
    • Remove the three Phillips #00 screws (3.45 mm length).
    • Remove the five Phillips #00 screws (2.9 mm length).
  9. Huawei Honor 9 Front Facing Camera Replacement: 步骤 9 中的图像 1,2 Huawei Honor 9 Front Facing Camera Replacement: 步骤 9 中的图像 2,2
    • Carefully peel up the black thermal foil and remove it completely.
    • This foil is very thin and brittle and may rip easily.
    • Remove the Phillips #00 screw that is located underneath the thermal foil at the bottom center of the motherboard.
  10. Huawei Honor 9 Front Facing Camera Replacement: 步骤 10 中的图像 1,2 Huawei Honor 9 Front Facing Camera Replacement: 步骤 10 中的图像 2,2
    • Slide an opening pick under the right side of the motherboard shield.
    • Twist the opening pick sideways to release the clips that hold the shield in place.
    • Repeat the previous process and work your way around the motherboard shield until it pops out.
  11. Huawei Honor 9 Front Facing Camera Replacement: 步骤 11 中的图像 1,1
    • Remove the motherboard shield.
  12. Huawei Honor 9 Front Facing Camera Replacement, Disconnect the Battery: 步骤 12 中的图像 1,2 Huawei Honor 9 Front Facing Camera Replacement, Disconnect the Battery: 步骤 12 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery flex cable.
  13. Huawei Honor 9 Front Facing Camera Replacement, Remove the Front-facing Camera: 步骤 13 中的图像 1,2 Huawei Honor 9 Front Facing Camera Replacement, Remove the Front-facing Camera: 步骤 13 中的图像 2,2
    • Use a spudger to pry up and disconnect the front-facing camera flex cable.
  14. Huawei Honor 9 Front Facing Camera Replacement: 步骤 14 中的图像 1,2 Huawei Honor 9 Front Facing Camera Replacement: 步骤 14 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to lift the front facing camera out of its recess.
    • Remove the front facing camera.
结论
Dominik Schnabelrauch
于11/23/16注册
229,498 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,455篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 10
总计 791
