跳转到主内容
Huawei Honor 8 Rear Glass Removal
你所需要的
  1. Huawei Honor 8 Rear Glass Removal, Rear Glass: 步骤 1 中的图像 1,1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Huawei Honor 8 Rear Glass Removal: 步骤 2 中的图像 1,3 Huawei Honor 8 Rear Glass Removal: 步骤 2 中的图像 2,3 Huawei Honor 8 Rear Glass Removal: 步骤 2 中的图像 3,3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • Lift the rear glass with the suction cup to create a small gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei Honor 8 Rear Glass Removal: 步骤 3 中的图像 1,2 Huawei Honor 8 Rear Glass Removal: 步骤 3 中的图像 2,2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei Honor 8 Rear Glass Removal: 步骤 4 中的图像 1,3 Huawei Honor 8 Rear Glass Removal: 步骤 4 中的图像 2,3 Huawei Honor 8 Rear Glass Removal: 步骤 4 中的图像 3,3
    • The fingerprint cable is located above the power and volume buttons on this side of the phone. Only use the tip of the opening pick in this area to avoid damage.
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the tip of the opening pick from the bottom left corner along the side to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei Honor 8 Rear Glass Removal: 步骤 5 中的图像 1,2 Huawei Honor 8 Rear Glass Removal: 步骤 5 中的图像 2,2
    • If the adhesive gets hard to cut it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei Honor 8 Rear Glass Removal: 步骤 6 中的图像 1,2 Huawei Honor 8 Rear Glass Removal: 步骤 6 中的图像 2,2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
    • The fingerprint cable is still connected to the motherboard. Don't try to remove the rear glass all the way yet.
  7. Huawei Honor 8 Rear Glass Removal: 步骤 7 中的图像 1,2 Huawei Honor 8 Rear Glass Removal: 步骤 7 中的图像 2,2
    • Carefully lift the rear glass and fold it to the left side of the Honor 8.
  8. Huawei Honor 8 Rear Glass Removal: 步骤 8 中的图像 1,1
    • Remove the Phillips #00 screw (2.8 mm length) that secures the metal bracket on top of the fingerprint flex connector.
  9. Huawei Honor 8 Rear Glass Removal: 步骤 9 中的图像 1,2 Huawei Honor 8 Rear Glass Removal: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the metal bracket that sits on top of the fingerprint and display flex connectors.
  10. Huawei Honor 8 Rear Glass Removal: 步骤 10 中的图像 1,2 Huawei Honor 8 Rear Glass Removal: 步骤 10 中的图像 2,2
    • Use a spudger to pry up and disconnect the fingerprint flex connector.
结论
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
2等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
229,304 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,448篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 76
过去 30 天: 86
总计 2,244
