跳转到主内容
Huawei Honor 8 Rear Glass & Frame Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Huawei Honor 8 Rear Glass & Frame Replacement, Rear Glass & Frame: 步骤 1 中的图像 1,1
    • Make sure you spend at least 5 minutes heating up the adhesive. Prying off the glass cover too early can result in cracking the panel.
    • Using a heat gun or hairdryer, apply heat approximately three inches above the glass panel to warm up the adhesive around the outside edge of the phone.
    • Make sure to apply heat evenly across the outside edge of the device.
  2. Huawei Honor 8 Rear Glass & Frame Replacement: 步骤 2 中的图像 1,2 Huawei Honor 8 Rear Glass & Frame Replacement: 步骤 2 中的图像 2,2
    • Be careful not to tear the orange ribbon wire when removing the back panel.
    • Using a plastic opening tool, gently pry up a corner of the rear glass panel.
    • Slowly slide the plastic opening tool around the outside of the glass panel to break through the adhesive.
    • Additional plastic opening tools can be used to help separate the back panel from the phone body.
    • Gently lift the back panel off once all the adhesive has been removed.
  3. Huawei Honor 8 Rear Glass & Frame Replacement: 步骤 3 中的图像 1,3 Huawei Honor 8 Rear Glass & Frame Replacement: 步骤 3 中的图像 2,3 Huawei Honor 8 Rear Glass & Frame Replacement: 步骤 3 中的图像 3,3
    • Using a Phillips PH00 screwdriver, remove the silver Phillips 3.5 mm screw circled in red.
    • Using a spudger, gently lift off the small metal tab that was held in place by the screw.
    • Gently pry off the orange ribbon wire on the back panel.
  4. Huawei Honor 8 Rear Glass & Frame Replacement: 步骤 4 中的图像 1,1
    • Keep the tiny screws on a magnetic pad or a designated area so they will not be lost. There are eighteen screws in total.
    • Using a Phillips PH00 screwdriver, remove the eight silver Phillips 3.5 mm screws circled in red.
    • Using a Phillips PH00 screwdriver, remove the six black Phillips 4.0 mm screws circled in orange.
    • Using a Phillips PH00 screwdriver, remove the single silver 3.0 mm Phillips screw circled in yellow.
    • Using the Phillips PH00 screwdriver tip, gently scratch away the white stickers outlined in green circles to expose hidden screws.
    • Using a Phillips PH00 screwdriver, remove the two black Phillips 4.0 mm screws circled in green.
  5. Huawei Honor 8 Rear Glass & Frame Replacement: 步骤 5 中的图像 1,3 Huawei Honor 8 Rear Glass & Frame Replacement: 步骤 5 中的图像 2,3 Huawei Honor 8 Rear Glass & Frame Replacement: 步骤 5 中的图像 3,3
    • Slowly slide the plastic opening tool around the perimeter of the inner lining.
    • Additional plastic opening tools can be used to help separate the inner lining from the phone body.
    • Gently pull the inner lining up to remove it from the phone body.
结论
5等其他人完成本指南。
Jaret Wedow
于09/25/17注册
1,800 声望
创作了4篇指南
团队
Cal Poly, Team S18-G2, Forte Fall 2017 Cal Poly, Team S18-G2, Forte Fall 2017 的会员
CPSU-FORTE-F17S18G2
4 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 5,073
