跳转到主内容
Huawei Honor 5X Volume and Power Buttons Replacement
你所需要的
  1. Huawei Honor 5X Volume and Power Buttons Replacement, HUAWEI HONOR 5X Disassembly: 步骤 1 中的图像 1,1
    • Turn off your cell phone before disassembling.
  2. Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 2 中的图像 1,1
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 3 中的图像 1,2 Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 3 中的图像 2,2
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 4 中的图像 1,1
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 5 中的图像 1,2 Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 5 中的图像 2,2
    • Pry off the back with a plastic opening tool.
  6. Huawei Honor 5X Volume and Power Buttons Replacement, Battery: 步骤 6 中的图像 1,1
    • Remove the pink sticker.
  7. Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 7 中的图像 1,1
    • Remove the three 1.5mm Phillips #000 screws.
  8. Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 8 中的图像 1,2 Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to disconnect the orange and black battery cables from the motherboard.
  9. Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 9 中的图像 1,1
    • Remove the battery from the phone.
  10. Huawei Honor 5X Volume and Power Buttons Replacement, Motherboard: 步骤 10 中的图像 1,2 Huawei Honor 5X Volume and Power Buttons Replacement, Motherboard: 步骤 10 中的图像 2,2
    • Remove the five 1.5mm Phillips #000 screws from the motherboard.
  11. Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 11 中的图像 1,2 Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
    • Use tweezers to disconnect the white coax cable.
    • Use tweezers to disconnect the power and volume cable.
  12. Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 12 中的图像 1,3 Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 12 中的图像 2,3 Huawei Honor 5X Volume and Power Buttons Replacement: 步骤 12 中的图像 3,3
    • Remove the motherboard.
  13. Huawei Honor 5X Volume and Power Buttons Replacement, Volume and Power Buttons: 步骤 13 中的图像 1,2 Huawei Honor 5X Volume and Power Buttons Replacement, Volume and Power Buttons: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    • Use the tweezers to pull the button assembly from the small black clips on the back plate of the phone.
结论
Eric Petrous
于09/03/19注册
145 声望
创作了2篇指南
团队
IUPUI, Team S1-G4, Hovde Fall 2019 IUPUI, Team S1-G4, Hovde Fall 2019 的会员
IUPUI-HOVDE-F19S1G4
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 38
总计 1,107
