跳转到主内容
Huawei Honor 10 Rear Cameras Replacement
你所需要的
  1. Huawei Honor 10 Rear Cameras Replacement, Rear Glass: 步骤 1 中的图像 1,1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Huawei Honor 10 Rear Cameras Replacement: 步骤 2 中的图像 1,3 Huawei Honor 10 Rear Cameras Replacement: 步骤 2 中的图像 2,3 Huawei Honor 10 Rear Cameras Replacement: 步骤 2 中的图像 3,3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
    • Insert the tip of an opening pick in the gap you created and slide it to the bottom right corner.
  3. Huawei Honor 10 Rear Cameras Replacement: 步骤 3 中的图像 1,2 Huawei Honor 10 Rear Cameras Replacement: 步骤 3 中的图像 2,2
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Insert a second opening pick at the bottom right corner of the rear glass.
    • Slide the opening pick along the bottom edge of the rear glass to cut the adhesive and leave it in the bottom left corner.
  4. Huawei Honor 10 Rear Cameras Replacement: 步骤 4 中的图像 1,3 Huawei Honor 10 Rear Cameras Replacement: 步骤 4 中的图像 2,3 Huawei Honor 10 Rear Cameras Replacement: 步骤 4 中的图像 3,3
    • Insert a third opening pick at the bottom left corner of the rear glass.
    • Slide the opening pick along the left edge of the rear glass to cut the adhesive.
    • Leave the opening pick at the top left corner of the rear glass.
  5. Huawei Honor 10 Rear Cameras Replacement: 步骤 5 中的图像 1,2 Huawei Honor 10 Rear Cameras Replacement: 步骤 5 中的图像 2,2
    • Insert a fourth opening pick at the top left corner of the rear glass.
    • Slide the opening along the top edge of the rear glass and cut the remaining adhesive with it.
  6. Huawei Honor 10 Rear Cameras Replacement: 步骤 6 中的图像 1,2 Huawei Honor 10 Rear Cameras Replacement: 步骤 6 中的图像 2,2
    • Carefully lift the rear glass of the Huawei Honor 10 and remove it.
  7. Huawei Honor 10 Rear Cameras Replacement, Battery disconnect: 步骤 7 中的图像 1,3 Huawei Honor 10 Rear Cameras Replacement, Battery disconnect: 步骤 7 中的图像 2,3 Huawei Honor 10 Rear Cameras Replacement, Battery disconnect: 步骤 7 中的图像 3,3
    • Use a pair of tweezer to carefully peel the black foil off the loudspeaker and daughterboard cover.
    • Remove the foil completely.
  8. Huawei Honor 10 Rear Cameras Replacement: 步骤 8 中的图像 1,1
    • Remove the three Phillips #00 screws (2.9 mm length) that secure the metal bracket on top of the battery, interconnect, and display flex cable.
  9. Huawei Honor 10 Rear Cameras Replacement: 步骤 9 中的图像 1,2 Huawei Honor 10 Rear Cameras Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the metal shield that covers the connectors of the interconnect cable, the battery and the display flex cable.
  10. Huawei Honor 10 Rear Cameras Replacement: 步骤 10 中的图像 1,2 Huawei Honor 10 Rear Cameras Replacement: 步骤 10 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery flex cable.
  11. Huawei Honor 10 Rear Cameras Replacement, Motherboard Cover: 步骤 11 中的图像 1,1
    • Remove the six Phillips screws securing the motherboard cover:
    • Four 3.4 mm long screws
    • Two 2.9 mm long screws
  12. Huawei Honor 10 Rear Cameras Replacement: 步骤 12 中的图像 1,3 Huawei Honor 10 Rear Cameras Replacement: 步骤 12 中的图像 2,3 Huawei Honor 10 Rear Cameras Replacement: 步骤 12 中的图像 3,3
    • Slide an opening pick under the motherboard cover next to the cameras and carefully pry it up by twisting the opening pick sideways.
    • Repeat the previous process on the opposite side of the motherboard cover until the cover pops out.
    • Remove the motherboard cover.
  13. Huawei Honor 10 Rear Cameras Replacement, Rear Cameras: 步骤 13 中的图像 1,2 Huawei Honor 10 Rear Cameras Replacement, Rear Cameras: 步骤 13 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the flex cable for the rear cameras.
  14. Huawei Honor 10 Rear Cameras Replacement: 步骤 14 中的图像 1,2 Huawei Honor 10 Rear Cameras Replacement: 步骤 14 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the rear cameras.
结论
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Dominik Schnabelrauch
于11/23/16注册
230,209 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,537篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 43
总计 822
