跳转到主内容
How to unpair a Mitsubishi MMCS NR-242 Map SD Card
你所需要的
  1. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Identify your Revision: 步骤 1 中的图像 1,1
    • You can find the Version Number of your MMCS printed on the top right corner of the unit.
    • You need either a Version W-11 or W-12. In this case the Version Number is W-12, so we can proceed.
  2. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Download the Unlock Binary: 步骤 2 中的图像 1,1
    • You can download the Binary at this site.
    • Download the Binary.
    • Extract the NK.BIN file from the W12_MAP_UNLOCKER.rar archive using 7-Zip.
  3. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Move the File: 步骤 3 中的图像 1,1
    • The SD card needs to be formatted to FAT32. If it’s not already formatted to FAT32 and you don’t know how to do it, you can take a look at this guide.
    • Copy the NK.BIN file to the root directory of the SD Card.
  4. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Flip up the Display: 步骤 4 中的图像 1,2 How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Flip up the Display: 步骤 4 中的图像 2,2
    • Press the OPEN-Button.
    • Press the Monitor OPEN-Button on the screen.
  5. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Swap the SD Cards: 步骤 5 中的图像 1,2 How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Swap the SD Cards: 步骤 5 中的图像 2,2
    • Remove the SD Cards from both the MAP and USER-Slots.
    • Insert the new SD Card into the USER-Slot.
    • Close the display by pressing the Open-Button again.
  6. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Reboot the Unit: 步骤 6 中的图像 1,1
    • Long press both the NAVI MENU and AUDIO-Buttons to reboot into unlocker mode.
  7. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Insert the paired SD Card: 步骤 7 中的图像 1,1
    • Open the display again by following the instructions in Step 4
    • Insert the paired SD Card into the MAP-Slot.
    • Wait 5-10 Seconds for the unpairing process to be completed before removing it again.
  8. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Return the SD Cards: 步骤 8 中的图像 1,1
    • Return the SD Cards you removed in Step 5 back to their respective Slots.
  9. How to unpair a Mitsubishi MMCS NR-242 Map SD Card, Exit the Unlocking Mode: 步骤 9 中的图像 1,1
    • Long press both the NAVI MENU and AUDIO-Buttons again to reboot back into standard mode.
结论
Drive safe!
Sebastian
于08/19/18注册
23,008 声望
创作了62篇指南
团队
German Translators German Translators 的会员
Community
28 名成员
创作了779篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 81
总计 1,014
