跳转到主内容
How to test an Ethernet Cable
你所需要的
  1. How to test an Ethernet Cable, Ports: 步骤 1 中的图像 1,2 How to test an Ethernet Cable, Ports: 步骤 1 中的图像 2,2
    • The tester has two ports on each part:
    • RJ11 (6P2C)
    • RJ45 (8P8C)
  2. How to test an Ethernet Cable, Connect the cable: 步骤 2 中的图像 1,1
    • Connect one end of the cable on one half of the tester each.
    • If you are testing jacks you can just connect them with a known good patch cable.
    • If the other side of your cable is already connected to a switch or some other device you can connect the MASTER device only.
    • Only do this with cable testers you trust, since crappy cable testers might not limit the current they send through the data lines.
  3. How to test an Ethernet Cable, Switch on the tester: 步骤 3 中的图像 1,1
    • Switch on the tester.
    • The tester has two modes: ON and S. There is no difference in the two modes besides the testing interval on S being more drawn out.
  4. How to test an Ethernet Cable, Test the cable: 步骤 4 中的图像 1,1
    • The tester will go through all the wires in sequence. If the sequence of the green lights blinking does not line up you might have swapped some wires when wiring the connector.
    • If some lights do not light up there might be a break in the cable or you made a mistake when crimping the connector.
    • For Fast Ethernet (100 Mbit/s) you only need pins 1, 2, 3 and 6. Some cheap cables may not even have more than these four wires.
    • G means ground. For most consumer applications up to 1GbE it should be fine if your ground is not properly connected.
结论
Good luck on your next project!
另外一个人完成了本指南。
Sebastian
于08/19/18注册
31,049 声望
创作了71篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 98
过去 30 天: 474
总计 18,501
