跳转到主内容
How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables
你所需要的
  1. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Clean up the ends: 步骤 1 中的图像 1,2 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Clean up the ends: 步骤 1 中的图像 2,2
    • Use wire cutters to make a clean cut on the end of the cable you want to strip.
  2. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the mantle: 步骤 2 中的图像 1,2 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the mantle: 步骤 2 中的图像 2,2
    • Grip the cable with a stripping tool for communication cables and twist it to cut the mantle.
    • Pull off the mantle.
    • It depends on what you want to do with the wire, but usually stripping off about 5cm is a pretty good starting point.
  3. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Remove the shielding: 步骤 3 中的图像 1,2 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Remove the shielding: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Flush Cutter
    $29.99
  4. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Remove the plastic foil: 步骤 4 中的图像 1,2 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Remove the plastic foil: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Flush Cutter
    $29.99
  5. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Pull back the grounding wire: 步骤 5 中的图像 1,2 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Pull back the grounding wire: 步骤 5 中的图像 2,2
    • Pull back the grounding wire and wrap it around the cable.
  6. How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the wire (optional): 步骤 6 中的图像 1,3 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the wire (optional): 步骤 6 中的图像 2,3 How to strip J-Y(ST)Y 2x2x0,8 Telecommunications Cables, Strip the wire (optional): 步骤 6 中的图像 3,3
    • Stripping the wire itself is optional, depending on what you want to do with it. P. ex. if you are going to punch it down into an LSA Plus block, you don't need to strip the wire.
    • Grip the wire with the 0.8 mm notch and pull off the insulation or use automatic wire strippers.
    • Stripping off 1cm is usually enough.
结论
Good luck on your next project!
2等其他人完成本指南。
Sebastian
于08/19/18注册
31,049 声望
创作了71篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 315
