跳转到主内容
How to replace the Azpen A720 Wi-Fi Antenna
你所需要的
  1. How to replace the Azpen A720 Wi-Fi Antenna, Back Cover: 步骤 1 中的图像 1,2 How to replace the Azpen A720 Wi-Fi Antenna, Back Cover: 步骤 1 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. How to replace the Azpen A720 Wi-Fi Antenna: 步骤 2 中的图像 1,3 How to replace the Azpen A720 Wi-Fi Antenna: 步骤 2 中的图像 2,3 How to replace the Azpen A720 Wi-Fi Antenna: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. How to replace the Azpen A720 Wi-Fi Antenna: 步骤 3 中的图像 1,1
    • Remove the rear casing.
  4. How to replace the Azpen A720 Wi-Fi Antenna, Wi-Fi Antenna: 步骤 4 中的图像 1,1
    • Locate the gray cord attached to the motherboard and the battery. This is the wifi antenna.
  5. How to replace the Azpen A720 Wi-Fi Antenna: 步骤 5 中的图像 1,2 How to replace the Azpen A720 Wi-Fi Antenna: 步骤 5 中的图像 2,2
    • Locate the soldering connection between the wifi antenna and the motherboard.
    • Using a soldering iron, melt the soldering connection between the cord and the motherboard and disconnect the cord.
    • The soldering iron gets very hot, be careful not to touch the tip to avoid burns. Click here to learn how to solder.
  6. How to replace the Azpen A720 Wi-Fi Antenna: 步骤 6 中的图像 1,2 How to replace the Azpen A720 Wi-Fi Antenna: 步骤 6 中的图像 2,2
    • Locate the black sticker connecting the wifi antenna to the battery.
    • Peel the black sticker off of the battery to disconnect the wifi antenna.
    • Remove and replace the defective wire.
结论
Anna
于03/17/15注册
353 声望
创作了3篇指南
团队
Michigan Tech, Team 1-3, Lauer Spring 2015 Michigan Tech, Team 1-3, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G3
2 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,241
