简介
As you can see by the photos, I took a broken and otherwise useless magsafe end and made a splice. After a resolder, the LED shows the computer charging.
你所需要的
This is a hyper extended end of a magsafe. It is no longer working due to the wire having pulled apart.
1.) Take the good end of the existing wire and strip it.
2.) The interior wire, which is coated in white should be soldered on a square metal plate about one eighth inch square. This plate is opposite a small chip for reference.
3.) The braided wire coats the white interior wire, and is wrapped around it in two different directions. This wire should be peeled off and then twisted together.
4.) Then solder it in place opposite the chip and the other wire.
21等其他人完成本指南。
14指南评论
Thanks a lot for the tutorial, worked like a charm and the result is quite clean too. You made me save 80€!
Works but looks like !@#$.
If it looks stupid, but it works, then it's not stupid. I'm certain someone has the skill to make that end look good.
040304 -
Awesome! I had not used my macbook for almost a month, since my magsafe quit working. I was afraid to cut into the plug, fearing I might damage the circuitry inside. Once I saw the pictures of the inside of the adapter, I knew the correct way to do it. Thank you for the tutorial. :)
