简介
In this guide, you will learn how to fix the problem with the front spool of your Tipp-Ex Pocket Mouse. The problem is caused by the spool being too small and not picking up the used tape properly, which leads to the tape tangling. Attention: Tipp-Ex is difficult to remove!
你所需要的
Open the red tab at the top of the housing or pull it off.
Use a screwdriver to carefully open the housing. Be careful not to use too much force so as not to damage the plastic or the pins.
Remove the top of the housing to expose the inner workings of the mouse.
Carefully remove the rubber that ensures the rollers roll up and down smoothly.
Make sure that the rollers do not come off.
Take the front, small and probably very full roll and unwind about 5 cm of ribbon.
Cut the ribbon.
Remove all plastic tape waste from the reel.
It is best to roll the waste directly into the waste garbage can.
Cut a 3 mm wide strip of scotch tape.
Use it to stick the Tipp-Ex tape back onto the roll.
Wind a few turns onto the roll.
Check the belt guide and tension of the belt.
Hold the encoder roller firmly and tighten the belt with the waste roller.
Put the mouse back together and press the lid firmly onto it.
If plastic parts were ruined when opening, you can glue them shut.
Your Tipp-Ex Pocket Mouse is now repaired and can be used again until the tape in the encoder roll is actually empty.
2等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
3条评论
I dun get a single ting. Very unclear
Very bad. Not clear. Cannot understand.
Die Beschreibung ist absolut korrekt. Danke!
