跳转到主内容
简介
If your Arbor Rally longboard has felt sluggish recently or you're not satisfied with it's performance, this guide will help you improve your ride.
工具
配件
  1. How to remove and clean Arbor Rally Longboard bearings, How to remove and clean Arbor Rally Longboard bearings: 步骤 1 中的图像 1,2 How to remove and clean Arbor Rally Longboard bearings, How to remove and clean Arbor Rally Longboard bearings: 步骤 1 中的图像 2,2
    • Use the half inch wrench to remove the nut on each wheel. Then remove each wheel.
    • Be careful not to lose the washers that sit between the nut and wheel, they are small and hard to find after you lose them.
  2. How to remove and clean Arbor Rally Longboard bearings: 步骤 2 中的图像 1,3 How to remove and clean Arbor Rally Longboard bearings: 步骤 2 中的图像 2,3 How to remove and clean Arbor Rally Longboard bearings: 步骤 2 中的图像 3,3
    • Use needle nose pliers to remove the bearings from both sides of each wheel.
  3. How to remove and clean Arbor Rally Longboard bearings: 步骤 3 中的图像 1,2 How to remove and clean Arbor Rally Longboard bearings: 步骤 3 中的图像 2,2
    • Place the bearings in soapy water and let them soak for 5 minutes.
  4. How to remove and clean Arbor Rally Longboard bearings: 步骤 4 中的图像 1,3 How to remove and clean Arbor Rally Longboard bearings: 步骤 4 中的图像 2,3 How to remove and clean Arbor Rally Longboard bearings: 步骤 4 中的图像 3,3
    • Wipe off the dirt from each bearing and dry them thoroughly with a paper towel.
  5. How to remove and clean Arbor Rally Longboard bearings: 步骤 5 中的图像 1,2 How to remove and clean Arbor Rally Longboard bearings: 步骤 5 中的图像 2,2
    • Apply a few drops of lubricant to the inner portion on both sides of each bearing.
    • Spin the bearings and wipe off any extra lubricant that has not settled in.
  6. How to remove and clean Arbor Rally Longboard bearings: 步骤 6 中的图像 1,3 How to remove and clean Arbor Rally Longboard bearings: 步骤 6 中的图像 2,3 How to remove and clean Arbor Rally Longboard bearings: 步骤 6 中的图像 3,3
    • Push the bearing into the wheel by applying even pressure with your thumb.
  7. How to remove and clean Arbor Rally Longboard bearings: 步骤 7 中的图像 1,3 How to remove and clean Arbor Rally Longboard bearings: 步骤 7 中的图像 2,3 How to remove and clean Arbor Rally Longboard bearings: 步骤 7 中的图像 3,3
    • Spin the wheel to make sure that the bearings are properly aligned and running smoothly.
  8. How to remove and clean Arbor Rally Longboard bearings: 步骤 8 中的图像 1,3 How to remove and clean Arbor Rally Longboard bearings: 步骤 8 中的图像 2,3 How to remove and clean Arbor Rally Longboard bearings: 步骤 8 中的图像 3,3
    • Place the wheel on the axle followed by washer and then the nut.
    • Tighten the nut with your fingers as much as you can first and then use the wrench to finish the job.
    • Do not tighten the nut too much or else the wheel will not be able to spin. You should be able to slightly shake the wheel up and down along the axle.
结论
4等其他人完成本指南。
Casey Barbello
于2013年07月24日注册
187 声望
撰写一个指南
团队
一条评论
Great guide! I was trying to figure out how to pop the bearings out - the needle nose pliers did a great job.
jewbot007 - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 83
总计 12,220
