跳转到主内容
How to open the TicWatchPro
你所需要的
  1. How to open the TicWatchPro, Unfasten the screws: 步骤 1 中的图像 1,1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the four 3.9 mm-long Torx T3 screws.
    • Depending on the condition of your driver, a Torx T4 bit may fit better.
    • Don't try to detach the back cover yet. It is still connected to the watch assembly.
  2. How to open the TicWatchPro, Open the watch: 步骤 2 中的图像 1,2 How to open the TicWatchPro, Open the watch: 步骤 2 中的图像 2,2
    • Be careful not to strain the sensor flex cable during this procedure.
    • Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
  3. How to open the TicWatchPro, Disconnect the sensor cable: 步骤 3 中的图像 1,2 How to open the TicWatchPro, Disconnect the sensor cable: 步骤 3 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
  4. How to open the TicWatchPro, Remove the back cover: 步骤 4 中的图像 1,1
    • Remove the back cover.
结论
Repair didn’t go as planned? Check out our Answers community for help.
2等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
247,094 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,657篇指南
2指南评论
T w lte 4G. Botón power como cambiar no conecta
yo tuve - 回复
Mostrar tutorial (si existe). gracias
yo tuve - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 2,002
