跳转到主内容
How to open the Fitbit Ionic
你所需要的
  1. How to open the Fitbit Ionic, How to open the Fitbit Ionic: 步骤 1 中的图像 1,2 How to open the Fitbit Ionic, How to open the Fitbit Ionic: 步骤 1 中的图像 2,2
    • Before starting, take your Fitbit Ionic off the charger and power it down.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  2. How to open the Fitbit Ionic: 步骤 2 中的图像 1,1
    • Heat an iOpener and apply it on the display for at least two minutes to soften the adhesive underneath.
    • The adhesive of the Fitbit Ionic is very strong. You may need to reheat the iOpener and repeat this procedure several times until the display adhesive gets loose enough.
  3. How to open the Fitbit Ionic: 步骤 3 中的图像 1,3 How to open the Fitbit Ionic: 步骤 3 中的图像 2,3 How to open the Fitbit Ionic: 步骤 3 中的图像 3,3
    • Insert a technician's razor with a flat blade into the small gap between the watch case and the display.
    • Cut through the adhesive on the upper side of the Fitbit Ionic.
  4. How to open the Fitbit Ionic: 步骤 4 中的图像 1,2 How to open the Fitbit Ionic: 步骤 4 中的图像 2,2
    • Use a technician's razor with a flat blade to pry up the top edge of the display and create a small gap.
  5. How to open the Fitbit Ionic: 步骤 5 中的图像 1,3 How to open the Fitbit Ionic: 步骤 5 中的图像 2,3 How to open the Fitbit Ionic: 步骤 5 中的图像 3,3
    • Insert two opening picks underneath the top left and the top right corner.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    • Remove the razor blade.
  6. How to open the Fitbit Ionic: 步骤 6 中的图像 1,2 How to open the Fitbit Ionic: 步骤 6 中的图像 2,2
    • Insert a third opening pick underneath the top right corner and slide it along the right edge of the display.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
  7. How to open the Fitbit Ionic: 步骤 7 中的图像 1,2 How to open the Fitbit Ionic: 步骤 7 中的图像 2,2
    • Insert a fourth opening pick underneath the top left corner and slide it along the left edge of the display.
    • Leave the opening pick in bottom left corner to prevent the adhesive from resealing.
    • Do not remove the display assembly all the way yet—it's still connected to the mainboard.
  8. How to open the Fitbit Ionic: 步骤 8 中的图像 1,2 How to open the Fitbit Ionic: 步骤 8 中的图像 2,2
    • Carefully fold the display assembly in the direction of the bottom edge.
结论
You’ll need replacement adhesive to reattach components when reassembling the device.
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
另外一个人完成了本指南。
Adriana Zwink
于12/18/19注册
62,444 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,738篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 4,433
