跳转到主内容
How to fix alignment on an E-TKT Label Printer
你所需要的
  1. How to fix alignment on an E-TKT Label Printer, Check the approximate alignment: 步骤 1 中的图像 1,2 How to fix alignment on an E-TKT Label Printer, Check the approximate alignment: 步骤 1 中的图像 2,2
    • Reboot the device.
    • After the splash screen the machine will home by rotating until the magnet meets the hall sensor.
    • Check the letter J position in the top window: If the letter is visually centered (second image), then you can skip ahead to to Step 3.
  2. How to fix alignment on an E-TKT Label Printer, Rough adjustment: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    • Turn off the device to avoid short circuiting the leads of the hall sensor.
    • Use blunt tweezers to finely adjust the hall sensor position along the tangential (cyan) axis as shown in the image:
    • If J is too much to the right, push the hall sensor toward the centre of the device (yellow arrow).
    • If J is too much to the left, pull the hall sensor towards yourself (magenta arrow).
    • Make sure to keep the same distance on the transversal (red) axis.
  3. How to fix alignment on an E-TKT Label Printer, Fine tuning: 步骤 3 中的图像 1,2 How to fix alignment on an E-TKT Label Printer, Fine tuning: 步骤 3 中的图像 2,2
    • Enter the web interface and click on SETUP.
    • Now press the TEST-button to the right side of ALIGN.
    • The machine will now slowly and lightly press the carousel letter, as shown in the second image.
    • Adjust the ALIGN-value until the press is fully centered on the character being pressed.
    • The align value ranges from 1 to 9, with 5 being the default (middle) value.
结论
Happy printing!
Sebastian
于08/19/18注册
31,157 声望
创作了71篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 245
