跳转到主内容
How to convert your Mac's storage from HFS to APFS file system
    • As a preventative measure, it is highly recommended you create an external backup drive to backup your files to
    • Typically converting your file system should not effect your data, but there is always a risk of loosing data when messing with the internal drive.
  1. How to convert your Mac's storage from HFS to APFS file system, Open Disk Utility and click on the View option: 步骤 2 中的图像 1,2 How to convert your Mac's storage from HFS to APFS file system, Open Disk Utility and click on the View option: 步骤 2 中的图像 2,2
    • Open the Disk Utility application and click the View option in the left hand corner.
    • From the drop down menu, choose the Show All Devices option from the list.
  2. How to convert your Mac's storage from HFS to APFS file system, Select the drive you want to convert: 步骤 3 中的图像 1,1
    • You should see a list of all your containing drives within each of their respective volume. Select the drive you want to convert and click the Partition button from the buttons in the upper right hand side of the window.
    • Make sure your Scheme is set to GUID Partition Map
    • Depending on the drive you're converting, your Scheme may be set to the "MS-DOS" format. In this case you would need to change the partition format.
    • Select Mac OS Extended (Journaled) from the "Format" dropdown menu.
    • Make sure the settings are correct, and click the Apply button.
    • Right click on the partition you set, and select Convert to APFS.
结论
Congratulations! You have successfully converted your drive to APFS. As stated previously, your files should have not been touched, always make sure everything is correct.
另外一个人完成了本指南。
Jacob Mehnert
于10/18/21注册
24,406 声望
创作了42篇指南
团队
iFanatics iFanatics 的会员
Community
54 名成员
创作了141篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 155
过去 30 天: 677
总计 13,017
