Make sure connector is completely dry before soldering, failure to do so may result in permanent damage.
If you have previously soldered inside the microphone, you may use a soldering iron to melt off any excess solder that may be on the pins inside the connector. Do not attempt this if you have never soldered on the microphone before.
