跳转到主内容
How to clean the Shure SM58
你所需要的
  1. How to clean the Shure SM58, Collar: 步骤 1 中的图像 1,3 How to clean the Shure SM58, Collar: 步骤 1 中的图像 2,3 How to clean the Shure SM58, Collar: 步骤 1 中的图像 3,3
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
  2. How to clean the Shure SM58, How to clean the Shure SM58: 步骤 2 中的图像 1,1
    • Create a mild cleaning solution by mixing a few drops of dish soap and water in a cup.
    • Using a detailing brush and the solution, gently brush the pins and inside walls of the microphone.
  3. How to clean the Shure SM58: 步骤 3 中的图像 1,1
    • Make sure connector is completely dry before soldering, failure to do so may result in permanent damage.
    • If you have previously soldered inside the microphone, you may use a soldering iron to melt off any excess solder that may be on the pins inside the connector. Do not attempt this if you have never soldered on the microphone before.
结论
After cleaning the faceplate and reassembling the microphone, it should work at its maximum potential.
另外一个人完成了本指南。
nat coll
于09/27/12注册
811 声望
创作了14篇指南
团队
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G53
5 名成员
创作了33篇指南
2指南评论
Thanks for the join. I’m checking out the Shure Sm-58 repair. Thanks for the info
Mike gallagher - 回复
Hi I checked the solder on the wires inside the microphone and it still does not work. Any other ideas?
karl_ivers - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 72
总计 11,587
