简介
If your jacket could talk, it would most likely have some pretty good stories. It would also probably ask you for an occasional bath. Washing your waterproof jacket is one of the best ways to increase its performance and longevity. There are no set rules as to when you should wash your jacket, but there are a few signs that the time has come: wetting out (no longer water repellent), stained cuffs or collar, or downright dirtiness! Washing your jacket is simple and will help your jacket to keep all your stories and secrets for another time.
Brush off any loose dirt or debris.
Particularly dirty spots should be pretreated. Make a soapy mixture with water and the detergent you intend to use and scrub the soiled area with a soft brush or sponge.
If you've got a particularly stubborn stain, check out Patagonia's Product Care guide.
Place the jacket in the washing machine and add the detergent
There are two types of recommended detergents:
Detergents designed specifically for the washing of technical outdoor gear that can be purchased at most outdoor gear stores
Water-based (not oil-based), biodegradable liquid detergent free of dye, whiteners, brighteners, or fragrance. Many of these detergents are marketed as " for sensitive skin"
More than one technical garment can be washed at once, but do not exceed more than half of the size of the washing machine drum
5等其他人完成本指南。
9条评论
I’m very happy after read this easy step of washing water proof jacket.Thanks for sharing this great post!!I bought water proof jacket from online store, and i got 60% off by using promo code; snow and rock promo codes.The jacket dries really fast and it’s 100% waterproof until i washed it.Color maintained very well, after it was washed.
The tips and suggestion was outstanding i try my husband jacket it was mess with factory work, i just buy my new washing machine from appliance connection with a reasonable prices appliances connection promo code and i get upto 40% discount on my first purchase you can also try.
Is it ok to wash two or three waterproof jackets together in the same load? Thank you!
White lining is flaking off ALL my Patagonia waterproof jackets - delaminated white liner. Refund the thousands of dollars I spent on this garbage?
They absolutely will replace it or give you store credit.
