跳转到主内容
加入维修社区 - 创建账户
How to Safely Raise a Vehicle Using Ramps
你所需要的
  1. How to Safely Raise a Vehicle Using Ramps, How to Safely Raise a Vehicle Using Ramps: 步骤 1 中的图像 1,1
    • Caution: Injury may result if this procedure is not followed properly. Be sure to follow each step carefully and follow all warnings.
    • To begin, park your vehicle on a firm, level surface such as concrete or asphalt.
    • Never try to raise your vehicle on soft or uneven terrain. If the ground shifts or the ramp changes position unexpectedly, you could be seriously injured or killed.
    • Center the steering wheel so that the front wheels point exactly straight ahead.
    询问修复机器人
    添加评论
  2. How to Safely Raise a Vehicle Using Ramps: 步骤 2 中的图像 1,2 How to Safely Raise a Vehicle Using Ramps: 步骤 2 中的图像 2,2
    • Slide the first ramp directly in front of the vehicle's front, driver-side wheel, until it touches the rubber of the tire.
    询问修复机器人
    添加评论
  3. How to Safely Raise a Vehicle Using Ramps: 步骤 3 中的图像 1,1
    • Put the second ramp into position directly in front of the vehicle's front, passenger-side wheel.
    询问修复机器人
    添加评论
  4. How to Safely Raise a Vehicle Using Ramps: 步骤 4 中的图像 1,1
    • Make sure each ramp is centered in the path of the tire so that once the vehicle moves forward, both wheels will stay completely supported by the ramps.
    询问修复机器人
    添加评论
  5. How to Safely Raise a Vehicle Using Ramps: 步骤 5 中的图像 1,2 How to Safely Raise a Vehicle Using Ramps: 步骤 5 中的图像 2,2
    • With the motor running and your vehicle in gear, begin slowly driving it straight forward onto the ramps.
    • Due to the steep incline of the ramps, you'll need to give it more gas than you might expect. At first, the vehicle may not move forward at all.
    • Slowly and steadily apply more throttle until the vehicle begins creeping up the ramps.
    • When doing this for the first time, be prepared to stop quickly in case you accidentally apply too much throttle. Either keep one foot on the brake pedal, or one hand on the e-brake lever. If your car has a manual transmission, use your left foot to feather the clutch pedal.
    询问修复机器人
    添加评论
  6. How to Safely Raise a Vehicle Using Ramps: 步骤 6 中的图像 1,2 How to Safely Raise a Vehicle Using Ramps: 步骤 6 中的图像 2,2
    • Continue driving slowly up the ramps until your vehicle levels out, and then stop immediately.
    • You can either find the correct place to stop purely by feel, or you can have a friend spot you from outside the vehicle.
    • Most automotive ramps have a slight dip at the top, or a bump stop, or both, to help stabilize the vehicle with the wheels in the correct position.
    • If you don't make it all the way up the ramps on the first try, that's okay—it can take several tries to get a feel for how the vehicle responds on the ramps. Let it roll back down, stop at the bottom, reposition the ramps and try again.
    询问修复机器人
    添加评论
  7. How to Safely Raise a Vehicle Using Ramps: 步骤 7 中的图像 1,3 How to Safely Raise a Vehicle Using Ramps: 步骤 7 中的图像 2,3 How to Safely Raise a Vehicle Using Ramps: 步骤 7 中的图像 3,3
    • With the front wheels in final position at the tops of the ramps:
    • Put the vehicle in Park (or first gear if you have a vehicle with a manual gearbox).
    • Set the parking brake.
    • Turn off the ignition and remove the ignition key.
    • Use extra care when exiting the vehicle, which is now raised much further from the ground than when you entered.
    添加评论
  8. How to Safely Raise a Vehicle Using Ramps: 步骤 8 中的图像 1,2 How to Safely Raise a Vehicle Using Ramps: 步骤 8 中的图像 2,2
    • Chock the rear wheels to prevent the vehicle from rolling backwards down the ramps.
    添加评论
结论
When your repair is complete, remove the wheel chocks and any other tools/obstructions before carefully backing your vehicle down and off the ramps.
取消:我没有完成这个指南。
9等其他人完成本指南。
Jeff Suovanen
于08/06/13注册
453,375 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了27,554篇指南
9指南评论
G’day Jeff
Thanks for the great guide! Very clear.
Question: Is it a bad idea to use just one ramp?
Say, for an oil change.
Stephen
Stephen Fujiwara - 回复 分享
Thanks for the guide, does the same ramp work for a regular sedan and an SUV? or it has to be different height? thanks
Dikran Kehyayan - 回复 分享
Hi Dikran,
You can use the same ramp for either vehicles. Be sure to check whether the ramps can handle the SUV’s weight.
Arthur Shi - 回复 分享
Good stuff. I still use ramps to change my oil simply because the amount of oil left in the vehicle due to the angle is negligible. 1 cup of oil remaining when I’ve removed and are adding in 4-5 quarts (16-20 cups) really isn’t a big deal unless you’re anal retentive.
Buster Ecks - 回复 分享
What ramps are being used in the pictures?
Andrew Morgan - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 44
过去 30 天: 245
总计 58,743
