本指南有最近更改,您可查看未经巡查的最新版本。
简介
Tire rotation ensures even wear on the tires. Front and rear axles support different weights, and will wear differently. Rotating tires allows for even wear on a set of four tires, maximizing the lifespan of the set.
You should rotate your tires every five thousand to ten thousand miles to reduce uneven tire wear.
你所需要的
Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
Once the car is raised, remove the lug nuts with the ratchet attached to a 3/4'' socket.
Follow these steps in the same order to rotate the tires on the other side of the vehicle.
6等其他人完成本指南。
一条评论
Really useful and valuable content, Thank you.
<a href="https://highwaypakistan.com/">highway trading comapny</a>
