跳转到主内容
How to Replace the Screen Adhesive on Your Switch Lite
你所需要的
  1. How to Replace the Screen Adhesive on Your Switch Lite, Apply isopropyl alcohol: 步骤 1 中的图像 1,3 How to Replace the Screen Adhesive on Your Switch Lite, Apply isopropyl alcohol: 步骤 1 中的图像 2,3 How to Replace the Screen Adhesive on Your Switch Lite, Apply isopropyl alcohol: 步骤 1 中的图像 3,3
    • Apply high concentration (90% or greater) isopropyl alcohol to the old screen adhesive on the frame.
    • Wait one minute to allow the alcohol to penetrate the adhesive.
  2. How to Replace the Screen Adhesive on Your Switch Lite, Remove the old adhesive: 步骤 2 中的图像 1,3 How to Replace the Screen Adhesive on Your Switch Lite, Remove the old adhesive: 步骤 2 中的图像 2,3 How to Replace the Screen Adhesive on Your Switch Lite, Remove the old adhesive: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • Use the flat end of a spudger to scrape all the old adhesive from the frame.
    • Use a microfiber cloth to clean the frame.
  3. How to Replace the Screen Adhesive on Your Switch Lite, Measure and cut the adhesive: 步骤 3 中的图像 1,3 How to Replace the Screen Adhesive on Your Switch Lite, Measure and cut the adhesive: 步骤 3 中的图像 2,3 How to Replace the Screen Adhesive on Your Switch Lite, Measure and cut the adhesive: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $5.99
    • Measure and cut four strips of 2 mm‑wide Tesa tape for the back of the screen:
    • Two strips for the long edges
    • Two strips for the short edges
    • You can use other adhesives, but make sure the strips are no wider than 3 mm.
  4. How to Replace the Screen Adhesive on Your Switch Lite, Apply the adhesive: 步骤 4 中的图像 1,3 How to Replace the Screen Adhesive on Your Switch Lite, Apply the adhesive: 步骤 4 中的图像 2,3 How to Replace the Screen Adhesive on Your Switch Lite, Apply the adhesive: 步骤 4 中的图像 3,3
    • Apply the adhesive strips sticky side down to the back of the screen, making sure the tape goes under the screen and digitizer cables.
  5. How to Replace the Screen Adhesive on Your Switch Lite: 步骤 5 中的图像 1,2 How to Replace the Screen Adhesive on Your Switch Lite: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the liners from the adhesive strips.
  6. How to Replace the Screen Adhesive on Your Switch Lite, Orient the screen: 步骤 6 中的图像 1,1
    • Orient the screen before adhering it to the frame:
    • The right edge of the screen has two wide cables that line up with the action buttons.
    • The left edge of the screen has one small cable that lines up with the directional pad.
  7. How to Replace the Screen Adhesive on Your Switch Lite, Place the screen on the frame: 步骤 7 中的图像 1,2 How to Replace the Screen Adhesive on Your Switch Lite, Place the screen on the frame: 步骤 7 中的图像 2,2
    • Lay the right edge of the screen on the frame at a downward angle, making sure its cables go under the frame.
  8. How to Replace the Screen Adhesive on Your Switch Lite: 步骤 8 中的图像 1,2 How to Replace the Screen Adhesive on Your Switch Lite: 步骤 8 中的图像 2,2
    • Lay the left edge of the screen onto the frame, making sure the small cable goes under the frame.
  9. How to Replace the Screen Adhesive on Your Switch Lite, Secure the new screen: 步骤 9 中的图像 1,2 How to Replace the Screen Adhesive on Your Switch Lite, Secure the new screen: 步骤 9 中的图像 2,2
    • Press down firmly around the perimeter of the screen to adhere it to the frame.
    • Make sure the top of the screen is flush with the frame.
终点
8等其他人完成本指南。
Spencer Day
于09/14/22注册
150,248 声望
创作了995篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,649篇指南
1指南评论
When reassessing the ifixit screen there’s a blue “film.” On the back of the screen inside the device on the new screen, should I take that off?
Noah Brown - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 76
过去 30 天: 339
总计 10,858
