跳转到主内容
How to Replace a Speaker on a Yamaha PSS-130 Keyboard
你所需要的
  1. How to Replace a Speaker on a Yamaha PSS-130 Keyboard, Internal Speaker: 步骤 1 中的图像 1,2 How to Replace a Speaker on a Yamaha PSS-130 Keyboard, Internal Speaker: 步骤 1 中的图像 2,2
    • Remove the battery cover.
    • Remove all twelve of the 9.0 mm screws on the back cover of the device's casing using a Phillips #1 screwdriver.
  2. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 2 中的图像 1,3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 2 中的图像 2,3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 2 中的图像 3,3
    • Place your fingers in the battery compartment, and place your thumb on the back of the keyboard.
    • Grip inside battery cover and push on the back of the keyboard with your thumb.
  3. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 3 中的图像 1,2 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 3 中的图像 2,2
    • Replace two 9.0 mm Phillips screws to keep the keys from falling out while working on this device.
  4. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 4 中的图像 1,3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 4 中的图像 2,3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 4 中的图像 3,3
    • Rotate the keyboard to get a better angle with the soldering iron.
  5. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 5 中的图像 1,1
    • Desolder the connections of the old speaker using the soldering iron and the solder wick.
  6. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 6 中的图像 1,3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 6 中的图像 2,3 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 6 中的图像 3,3
    • Remove the fasteners using an 11 mm socket wrench.
    • It will take very little torque to strip the plastic, so make sure that your wrench is turning them to the left.
  7. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 7 中的图像 1,2 How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 7 中的图像 2,2
    • The speaker should now be free. Simply lift the speaker out.
    • Using the same process, place the new speaker in the speaker indentation.
    • My own speaker was not malfunctioning so I did not replace it.
  8. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 8 中的图像 1,1
    • Replace the fasteners that were removed in step 6, this time tightening to the right.
  9. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: 步骤 9 中的图像 1,1
    • Solder the new speaker to the wires taken off in step 5.
结论
To reassemble your device, follow these instructions in reverse order from step 3.
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 558
