跳转到主内容
How to Replace a G-Shock GA201-1A Battery
你所需要的
  1. How to Replace a G-Shock GA201-1A Battery, Battery: 步骤 1 中的图像 1,3 How to Replace a G-Shock GA201-1A Battery, Battery: 步骤 1 中的图像 2,3 How to Replace a G-Shock GA201-1A Battery, Battery: 步骤 1 中的图像 3,3
    • Remove back cover by removing the four 6.2 mm Phillips #0 screws with the screwdriver.
    • Be careful not to lose the screws.
  2. How to Replace a G-Shock GA201-1A Battery: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to remove the rubber gasket by lifting it.
  3. How to Replace a G-Shock GA201-1A Battery: 步骤 3 中的图像 1,2 How to Replace a G-Shock GA201-1A Battery: 步骤 3 中的图像 2,2
    • Lift the white plastic covering with a pair of tweezers.
    • Be delicate; if too much force is applied, the watch's interior can pop out.
  4. How to Replace a G-Shock GA201-1A Battery: 步骤 4 中的图像 1,1
    • Peel off the protective sticker from the surface of the old battery.
  5. How to Replace a G-Shock GA201-1A Battery: 步骤 5 中的图像 1,1
    • Use tweezers to bend the metal guide away from the old battery.
  6. How to Replace a G-Shock GA201-1A Battery: 步骤 6 中的图像 1,1
    • Remove the old battery from the guide with tweezers.
  7. How to Replace a G-Shock GA201-1A Battery: 步骤 7 中的图像 1,2 How to Replace a G-Shock GA201-1A Battery: 步骤 7 中的图像 2,2
    • Slide the new battery into the frame and bend the metal guide onto the battery.
  8. How to Replace a G-Shock GA201-1A Battery: 步骤 8 中的图像 1,2 How to Replace a G-Shock GA201-1A Battery: 步骤 8 中的图像 2,2
    • Reset the proper time and date using the top-left "adjust" button.
    • For further instructions, consult your G-Shock GA-201 User Manual.
结论
To reassemble your watch, follow these instructions in reverse order.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Cordell Johnson
于09/28/21注册
157 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 91
过去 30 天: 488
总计 18,893
