跳转到主内容
How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.
你所需要的
  1. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower., How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 1 中的图像 1,1
    • Start with a flat, open space to work.
  2. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 2 中的图像 1,2 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 2 中的图像 2,2
    • Unscrew these three 1.2 mm screws.
  3. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 3 中的图像 1,1
    • Remove the Bubble Sprocket from the motor.
  4. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 4 中的图像 1,1
    • Unscrew these four 1.2mm screws holding the plate on.
  5. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 5 中的图像 1,1
    • Remove the plate.
  6. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 6 中的图像 1,1
    • Connect the red wire to the top right pin.
  7. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 7 中的图像 1,1
    • Solder the Red wire to the metal pin.
    • (Warning Soldering is very hot!)
  8. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 8 中的图像 1,2 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 8 中的图像 2,2
    • Connect the yellow wire to the bottom right pin.
    • Solder the yellow wire to the bottom right pin.
    • (Warning Soldering iron is very hot!)
  9. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 9 中的图像 1,1
    • Replace the plate over the wires.
  10. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 10 中的图像 1,1
    • Put four 1.2 mm screws for the plate back into place.
  11. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 11 中的图像 1,1
    • Put three 1.2mm screws for the motor back into place.
  12. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 12 中的图像 1,1
    • Insert the Bubble sprocket onto the motor.
  13. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: 步骤 13 中的图像 1,1
    • You are now finished!
终点
John Hiller
于10/05/15注册
110 声望
撰写一个指南
团队
Colorado Springs, Team 7-5, Mcmichael Fall 2015 Colorado Springs, Team 7-5, Mcmichael Fall 2015 的会员
UCCS-MCMICHAEL-F15S7G5
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 17
总计 1,813
