跳转到主内容
How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery
你所需要的
  1. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery, Battery: 步骤 1 中的图像 1,3 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery, Battery: 步骤 1 中的图像 2,3 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery, Battery: 步骤 1 中的图像 3,3
    • Set your gel blaster flat on a table.
    • Push the battery compartment release tab upwards.
    • Lift the battery cover and remove it.
  2. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 步骤 2 中的图像 1,3 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 步骤 2 中的图像 2,3 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 步骤 2 中的图像 3,3
    • Squeeze both the left and the right side of the release latch and pull apart the connector to remove the battery from the gel blaster's motor.
  3. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 步骤 3 中的图像 1,1
    • Remove the battery from the battery compartment.
  4. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 步骤 4 中的图像 1,2 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 步骤 4 中的图像 2,2
    • Use utility scissors to cut the first green layer of the battery.
    • Remove the first layer to expose the connection to the wire.
    • Be careful when cutting the top layer, and do not remove the inner plastic layer.
  5. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 步骤 5 中的图像 1,2 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 步骤 5 中的图像 2,2
    • Using the soldering iron and the lead-free solder, re-solder the wire to the battery to ensure a stable connection.
    • If there is any confusion on how to solder, please refer to the link below: How To Solder and Desolder Connections
  6. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 步骤 6 中的图像 1,2 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: 步骤 6 中的图像 2,2
    • Insert the battery back into the battery compartment.
    • Reconnect the battery to the motor.
    • Replace the cover to close the battery compartment.
结论
Bryan Mendoza
于02/10/23注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 76
总计 722
