跳转到主内容
How to Repair a Squareplug Patch Cable with SP400 Plugs
你所需要的
  1. How to Repair a Squareplug Patch Cable with SP400 Plugs, Patch Cables With SP400 Plugs: 步骤 1 中的图像 1,1
    • Verify that the cable is faulty (unresponsive yellow and green LED indicators).
    • Yellow LED indicator
    • Green LED indicator
    • If both the yellow and green LED indicators turn on, then the cable is not the source of any audio loss. Check the pedals, amp, guitar, or power supply for issues.
    • If the red LED turns on, then the cable is shorting and will also require a resolder.
  2. How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 2 中的图像 1,1
    • Unscrew the SP400 housing.
  3. How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 3 中的图像 1,3 How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 3 中的图像 2,3 How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 3 中的图像 3,3
    • Desolder the existing solder connections.
    • Wick the existing solder completely off of the plug connections.
    • Do not touch the plug or the wick directly while desoldering.
    • For more information on soldering, check out the How to Solder and Desolder Connections guide.
  4. How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 4 中的图像 1,2 How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 4 中的图像 2,2
    • Cut the ends of the cable using a pair of wire cutters to expose fresh wires.
  5. How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 5 中的图像 1,3 How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 5 中的图像 2,3 How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 5 中的图像 3,3
    • Strip the outer insulating jacket by ~1 cm.
    • The Eclipse UTP Stripper works especially well for this step.
    • Braid the ground wires.
  6. How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 6 中的图像 1,3 How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 6 中的图像 2,3 How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 6 中的图像 3,3
    • Strip the inner insulator by ~2mm.
    • Braid the signal wires.
  7. How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 7 中的图像 1,3 How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 7 中的图像 2,3 How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 7 中的图像 3,3
    • Tin the soldering iron tip, ground wire, signal wire, and plug connections.
    • Do not touch the plug or the solder directly while tinning.
  8. How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 8 中的图像 1,2 How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 8 中的图像 2,2
    • Solder the wires onto the plug connections:
    • Signal wire to the tip connection
    • Ground wire to the sleeve connection
    • The outer insulating jacket should slightly extend into the chamber of the plug to minimize cable movement.
    • Do not touch the plug directly while soldering.
  9. How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 9 中的图像 1,1
    • Screw the SP400 housing.
  10. How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 10 中的图像 1,2 How to Repair a Squareplug Patch Cable with SP400 Plugs: 步骤 10 中的图像 2,2
    • Verify that the cable is working (responsive yellow and green LED indicators).
终点
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 22
总计 885
