跳转到主内容
How to Remove the Middle Panel on a PlayStation 5
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. How to Remove the Middle Panel on a PlayStation 5, Remove the stand screw: 步骤 1 中的图像 1,1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. How to Remove the Middle Panel on a PlayStation 5, Remove the vertical stand: 步骤 2 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5, Remove the vertical stand: 步骤 2 中的图像 2,2
    • Lift straight up to remove the stand.
  3. How to Remove the Middle Panel on a PlayStation 5, Store the stand screw: 步骤 3 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5, Store the stand screw: 步骤 3 中的图像 2,2
    • Insert the screw into the cubby on the bottom of the stand.
  4. How to Remove the Middle Panel on a PlayStation 5, Cap the screw hole: 步骤 4 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Cap the screw hole: 步骤 4 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Cap the screw hole: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. How to Remove the Middle Panel on a PlayStation 5, Close the cubby: 步骤 5 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Close the cubby: 步骤 5 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Close the cubby: 步骤 5 中的图像 3,3
    • Twist the stand counterclockwise to close the cubby.
  6. How to Remove the Middle Panel on a PlayStation 5, Remove the horizontal stand: 步骤 6 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5, Remove the horizontal stand: 步骤 6 中的图像 2,2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. How to Remove the Middle Panel on a PlayStation 5, Remove the right faceplate: 步骤 7 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Remove the right faceplate: 步骤 7 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Remove the right faceplate: 步骤 7 中的图像 3,3
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  8. How to Remove the Middle Panel on a PlayStation 5: 步骤 8 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5: 步骤 8 中的图像 2,2
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
  9. How to Remove the Middle Panel on a PlayStation 5, Pry up the grille: 步骤 9 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Pry up the grille: 步骤 9 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Pry up the grille: 步骤 9 中的图像 3,3
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
  10. How to Remove the Middle Panel on a PlayStation 5, Remove the grille: 步骤 10 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5, Remove the grille: 步骤 10 中的图像 2,2
    • Lift the grille away from the case to remove it.
  11. How to Remove the Middle Panel on a PlayStation 5, Remove the fan shroud screws: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Use a T9 Torx Security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  12. How to Remove the Middle Panel on a PlayStation 5, Remove the fan shroud: 步骤 12 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5, Remove the fan shroud: 步骤 12 中的图像 2,2
    • Lift the fan shroud straight up to remove it.
  13. How to Remove the Middle Panel on a PlayStation 5, Remove the wire cover: 步骤 13 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Remove the wire cover: 步骤 13 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Remove the wire cover: 步骤 13 中的图像 3,3
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
  14. How to Remove the Middle Panel on a PlayStation 5: 步骤 14 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5: 步骤 14 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5: 步骤 14 中的图像 3,3
    • Use your fingers to peel off the wire cover.
  15. How to Remove the Middle Panel on a PlayStation 5, Disconnect the fan: 步骤 15 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5, Disconnect the fan: 步骤 15 中的图像 2,2
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  16. How to Remove the Middle Panel on a PlayStation 5, Remove the fan: 步骤 16 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Remove the fan: 步骤 16 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Remove the fan: 步骤 16 中的图像 3,3
    • Lift the fan up and out of the case to remove it.
  17. How to Remove the Middle Panel on a PlayStation 5, Remove the SSD cover: 步骤 17 中的图像 1,1
    • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
  18. How to Remove the Middle Panel on a PlayStation 5: 步骤 18 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5: 步骤 18 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5: 步骤 18 中的图像 3,3
    • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
    • Remove the SSD cover.
  19. How to Remove the Middle Panel on a PlayStation 5, Remove the optical drive wire: 步骤 19 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5, Remove the optical drive wire: 步骤 19 中的图像 2,2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
  20. How to Remove the Middle Panel on a PlayStation 5: 步骤 20 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5: 步骤 20 中的图像 2,2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
  21. How to Remove the Middle Panel on a PlayStation 5, Remove the tamper-evident sticker: 步骤 21 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Remove the tamper-evident sticker: 步骤 21 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Remove the tamper-evident sticker: 步骤 21 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
    • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
    • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
  22. How to Remove the Middle Panel on a PlayStation 5, Remove the case screws: 步骤 22 中的图像 1,1
    • Use a T8 Torx driver to remove the eleven screws securing the case:
    • Six 18.6 mm-long screws
    • Two 43.2 mm-long screws
    • One 7.3 mm-long screw
  23. How to Remove the Middle Panel on a PlayStation 5, Remove the case: 步骤 23 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5, Remove the case: 步骤 23 中的图像 2,2
    • Lift the case straight up to remove it.
  24. How to Remove the Middle Panel on a PlayStation 5, Remove the optical drive ribbon cable: 步骤 24 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Remove the optical drive ribbon cable: 步骤 24 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Remove the optical drive ribbon cable: 步骤 24 中的图像 3,3
    • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
    • Pull only on the pull tab, not the cable itself.
  25. How to Remove the Middle Panel on a PlayStation 5, Remove the optical drive: 步骤 25 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5, Remove the optical drive: 步骤 25 中的图像 2,2
    • Lift the optical drive away from the device to remove it.
  26. How to Remove the Middle Panel on a PlayStation 5, Remove the optical drive ribbon cable: 步骤 26 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Remove the optical drive ribbon cable: 步骤 26 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Remove the optical drive ribbon cable: 步骤 26 中的图像 3,3
    在这个步骤中使用的工具:
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
  27. How to Remove the Middle Panel on a PlayStation 5, Remove the power and eject button ribbon cable: 步骤 27 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5, Remove the power and eject button ribbon cable: 步骤 27 中的图像 2,2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
  28. How to Remove the Middle Panel on a PlayStation 5, Remove the LED ribbon cable: 步骤 28 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5, Remove the LED ribbon cable: 步骤 28 中的图像 2,2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
  29. How to Remove the Middle Panel on a PlayStation 5, Remove the antenna wires: 步骤 29 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Remove the antenna wires: 步骤 29 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Remove the antenna wires: 步骤 29 中的图像 3,3
    • Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
    • Lift the wire's connector straight up to disconnect it from the motherboard.
    • Repeat for the black Wi-Fi antenna wire.
    • Some board revisions may not have these antenna wires. If your board is missing these connectors, skip this step.
  30. How to Remove the Middle Panel on a PlayStation 5: 步骤 30 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5: 步骤 30 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5: 步骤 30 中的图像 3,3
    • Use a pair of tweezers to grip the black or blue power supply antenna wire at its metal base, as close to the connector as possible.
    • Repeat for the white power supply antenna wire.
  31. How to Remove the Middle Panel on a PlayStation 5, Remove the white stickers: 步骤 31 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Remove the white stickers: 步骤 31 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Remove the white stickers: 步骤 31 中的图像 3,3
    • Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
    • Remove the antenna wires from underneath the sticker.
    • Press the white sticker back down onto the top shield plate so it can be reused.
  32. How to Remove the Middle Panel on a PlayStation 5: 步骤 32 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5: 步骤 32 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5: 步骤 32 中的图像 3,3
    • Repeat the previous step to peel back the four remaining stickers.
  33. How to Remove the Middle Panel on a PlayStation 5: 步骤 33 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5: 步骤 33 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5: 步骤 33 中的图像 3,3
    • Use a pair of tweezers to peel back the white sticker holding the LED ribbon cable to the heat sink.
    • Remove the LED ribbon cable from underneath the sticker.
    • Press the white sticker back down onto the heat sink so it can be reused.
  34. How to Remove the Middle Panel on a PlayStation 5, Remove the top shield plate screws: 步骤 34 中的图像 1,1
    • Use a T8 Torx driver to remove the forty-two screws securing the top shield plate:
    • Forty-one 7.3 mm-long screws
    • One 43.2 mm-long screw
  35. How to Remove the Middle Panel on a PlayStation 5, Remove the top shield plate: 步骤 35 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Remove the top shield plate: 步骤 35 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Remove the top shield plate: 步骤 35 中的图像 3,3
    • Lift the top shield plate off of the motherboard to remove it.
    • During reassembly, this is a good point to replace any thermal pads on the top of the main board, if necessary. The pads may be stuck to both the top shield plate and the main board.
    • It's important that the replacement pads are the same thickness as the originals, otherwise the foam around the APU may not seal properly.
  36. How to Remove the Middle Panel on a PlayStation 5, Disconnect the USB board: 步骤 36 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Disconnect the USB board: 步骤 36 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Disconnect the USB board: 步骤 36 中的图像 3,3
    • Use your finger to depress the metal locking tab on the USB board cable's board connector.
    • With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
  37. How to Remove the Middle Panel on a PlayStation 5, Remove the left faceplate: 步骤 37 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Remove the left faceplate: 步骤 37 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Remove the left faceplate: 步骤 37 中的图像 3,3
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  38. How to Remove the Middle Panel on a PlayStation 5: 步骤 38 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5: 步骤 38 中的图像 2,2
    • Remove the left faceplate.
  39. How to Remove the Middle Panel on a PlayStation 5, Remove the screws: 步骤 39 中的图像 1,1
    • Use a Torx T8 driver to remove the two 29.4 mm-long screws securing the case to the motherboard and heat sink assembly.
  40. How to Remove the Middle Panel on a PlayStation 5, Remove the case: 步骤 40 中的图像 1,3 How to Remove the Middle Panel on a PlayStation 5, Remove the case: 步骤 40 中的图像 2,3 How to Remove the Middle Panel on a PlayStation 5, Remove the case: 步骤 40 中的图像 3,3
    • Lift the front edge of the case off of the motherboard and heat sink assembly.
    • With the front edge elevated, push the case back, away from the motherboard and heat sink assembly, to maneuver the charging port out of its slot in the case.
    • Remove the case.
    • The front plate may come apart from the plastic case. During reassembly, make sure the front plate is in place before reinserting the motherboard and power supply.
  41. How to Remove the Middle Panel on a PlayStation 5, Remove the middle panel: 步骤 41 中的图像 1,2 How to Remove the Middle Panel on a PlayStation 5, Remove the middle panel: 步骤 41 中的图像 2,2
    • Lift up to remove the middle panel from the case.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
Robert Boyd
于02/01/21注册
31,676 声望
创作了94篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 83
