跳转到主内容
How to Remove the Freezer Drawer on an LG Refrigerator
你所需要的
  1. How to Remove the Freezer Drawer on an LG Refrigerator, Unplug your refrigerator: 步骤 1 中的图像 1,1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. How to Remove the Freezer Drawer on an LG Refrigerator, Open the freezer door: 步骤 2 中的图像 1,2 How to Remove the Freezer Drawer on an LG Refrigerator, Open the freezer door: 步骤 2 中的图像 2,2
    • Pull open the freezer door fully.
  3. How to Remove the Freezer Drawer on an LG Refrigerator, Remove the drawer and bin: 步骤 3 中的图像 1,3 How to Remove the Freezer Drawer on an LG Refrigerator, Remove the drawer and bin: 步骤 3 中的图像 2,3 How to Remove the Freezer Drawer on an LG Refrigerator, Remove the drawer and bin: 步骤 3 中的图像 3,3
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. How to Remove the Freezer Drawer on an LG Refrigerator, Remove the drawer rail covers: 步骤 4 中的图像 1,3 How to Remove the Freezer Drawer on an LG Refrigerator, Remove the drawer rail covers: 步骤 4 中的图像 2,3 How to Remove the Freezer Drawer on an LG Refrigerator, Remove the drawer rail covers: 步骤 4 中的图像 3,3
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. How to Remove the Freezer Drawer on an LG Refrigerator, Reassembly notes: 步骤 5 中的图像 1,2 How to Remove the Freezer Drawer on an LG Refrigerator, Reassembly notes: 步骤 5 中的图像 2,2
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. How to Remove the Freezer Drawer on an LG Refrigerator, Remove the drawer: 步骤 6 中的图像 1,2 How to Remove the Freezer Drawer on an LG Refrigerator, Remove the drawer: 步骤 6 中的图像 2,2
    • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
  7. How to Remove the Freezer Drawer on an LG Refrigerator: 步骤 7 中的图像 1,3 How to Remove the Freezer Drawer on an LG Refrigerator: 步骤 7 中的图像 2,3 How to Remove the Freezer Drawer on an LG Refrigerator: 步骤 7 中的图像 3,3
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
另外一个人完成了本指南。
Bill Gilbert
于06/30/22注册
38,528 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,779篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 25
过去 7 天: 149
过去 30 天: 668
总计 15,178
