跳转到主内容
How to Reinforce the Base of a Torn Backpack
你所需要的
  1. How to Reinforce the Base of a Torn Backpack, Backpack Base: 步骤 1 中的图像 1,1
    • Pull out any excess thread that is left over from the tear.
    • Make sure to be careful in pulling the thread to avoid causing excess damage.
  2. How to Reinforce the Base of a Torn Backpack: 步骤 2 中的图像 1,1
    • Turn the backpack inside out.
    • Carefully do this to not make the hole bigger.
  3. How to Reinforce the Base of a Torn Backpack: 步骤 3 中的图像 1,2 How to Reinforce the Base of a Torn Backpack: 步骤 3 中的图像 2,2
    • Pin the hole together using sewing pins.
    • Gently pin to avoid poking or hurting yourself with the pins.
  4. How to Reinforce the Base of a Torn Backpack: 步骤 4 中的图像 1,2 How to Reinforce the Base of a Torn Backpack: 步骤 4 中的图像 2,2
    • Thread your needle with a similar color thread to your backpack.
    • Tie a knot at the end of the thread.
  5. How to Reinforce the Base of a Torn Backpack: 步骤 5 中的图像 1,3 How to Reinforce the Base of a Torn Backpack: 步骤 5 中的图像 2,3 How to Reinforce the Base of a Torn Backpack: 步骤 5 中的图像 3,3
    • Sew the hole shut, removing pins as you go.
    • Use this Basic Sewing guide for exact stitching.
    • Unpin carefully to avoid poking or hurting yourself with the pins
    • Tie a knot at the end to close off the stitch.
    • Cut any excess thread.
  6. How to Reinforce the Base of a Torn Backpack: 步骤 6 中的图像 1,3 How to Reinforce the Base of a Torn Backpack: 步骤 6 中的图像 2,3 How to Reinforce the Base of a Torn Backpack: 步骤 6 中的图像 3,3
    • Trace an additional piece of lining with ¼” seam allowance in the shape of the backpack bottom.
    • Cut the fabric for the lining.
    • Pin the fabric around the perimeter to the base of the backpack.
  7. How to Reinforce the Base of a Torn Backpack: 步骤 7 中的图像 1,1
    • Sew the lining to the base of the inside out backpack using the same process in Step 5.
    • Use this Basic Sewing tutorial as needed.
    • Gently sew and unpin to avoid hurting yourself with the pins.
  8. How to Reinforce the Base of a Torn Backpack: 步骤 8 中的图像 1,1
    • Enjoy your newly strengthened backpack!
结论
Congratulations you have now reinforced and repaired your backpack! Good as new if not better.
另外一个人完成了本指南。
Amber Irfan
于02/02/24注册
169 声望
撰写一个指南
团队
UC Davis, Team 4-4, Andersen Winter 2024 UC Davis, Team 4-4, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S4G4
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 47
总计 1,039
