跳转到主内容
加入维修社区 - 创建账户
Sew a Ladder Stitch
你所需要的
  1. Sew a Ladder Stitch, Sew a Ladder Stitch: 步骤 1 中的图像 1,3 Sew a Ladder Stitch, Sew a Ladder Stitch: 步骤 1 中的图像 2,3 Sew a Ladder Stitch, Sew a Ladder Stitch: 步骤 1 中的图像 3,3
    • Thread your needle and tie a knot in the end.
    • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
    • Drive the needle from the back of the material, just before where the tear starts.
    • Pull the thread taut.
  2. Sew a Ladder Stitch: 步骤 2 中的图像 1,2 Sew a Ladder Stitch: 步骤 2 中的图像 2,2
    • Take a small stitch, going in and out of the material, on one side of the tear only.
  3. Sew a Ladder Stitch: 步骤 3 中的图像 1,2 Sew a Ladder Stitch: 步骤 3 中的图像 2,2
    • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
    • Pull the thread taut. This should cinch the material together.
    • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
  4. Sew a Ladder Stitch: 步骤 4 中的图像 1,2 Sew a Ladder Stitch: 步骤 4 中的图像 2,2
    • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
    • Stitch until you come to the end of the tear.
  5. Sew a Ladder Stitch: 步骤 5 中的图像 1,3 Sew a Ladder Stitch: 步骤 5 中的图像 2,3 Sew a Ladder Stitch: 步骤 5 中的图像 3,3
    • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
    • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
    • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • Ensure that the stitches are tight, and cut any excess threads.
终点
2等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
90,755 声望
创作了142篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 46
过去 30 天: 221
总计 14,402
