跳转到主内容
How to Perform a Battery Cycle Reset
  1. How to Perform a Battery Cycle Reset, Download the app: 步骤 1 中的图像 1,3 How to Perform a Battery Cycle Reset, Download the app: 步骤 1 中的图像 2,3 How to Perform a Battery Cycle Reset, Download the app: 步骤 1 中的图像 3,3
    • Download the Self Repair Assistant app (2.0.12)here.
    • You may be prompted with a "File might be harmful" warning. If so, select "Download anyway."
    • Open the "My Files" app.
    • Navigate to the "Installation files" tab on the left side of the screen.
  2. How to Perform a Battery Cycle Reset, Install the app: 步骤 2 中的图像 1,2 How to Perform a Battery Cycle Reset, Install the app: 步骤 2 中的图像 2,2
    • Select the app on the right side of the screen.
    • If the app doesn't show up on this panel, skip to the next step.
    • Select "Install" to confirm the app's installation.
    • Skip the next two steps.
  3. How to Perform a Battery Cycle Reset, Rename the app: 步骤 3 中的图像 1,3 How to Perform a Battery Cycle Reset, Rename the app: 步骤 3 中的图像 2,3 How to Perform a Battery Cycle Reset, Rename the app: 步骤 3 中的图像 3,3
    • If your app didn't show up on the "Installation files" tab, follow the next two steps to rename the file.
    • Navigate to the "Downloads" tab on the left side of the screen.
    • Long press the download file until an orange checkmark appears to the left of it.
    • Navigate to the bottom of the screen and select the "More" option.
  4. How to Perform a Battery Cycle Reset: 步骤 4 中的图像 1,3 How to Perform a Battery Cycle Reset: 步骤 4 中的图像 2,3 How to Perform a Battery Cycle Reset: 步骤 4 中的图像 3,3
    • Select the "Rename" option.
    • Delete the .jar at the end of the app's name.
    • Your file should now appear in the "Installation files" tab.
  5. How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: 步骤 5 中的图像 1,2 How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: 步骤 5 中的图像 2,2
    • Select the Galaxy Cal app.
  6. How to Perform a Battery Cycle Reset, Agree to the terms and conditions: 步骤 6 中的图像 1,1
    • Select "Agree" to accept the Terms and Conditions.
  7. How to Perform a Battery Cycle Reset, Select the procedure: 步骤 7 中的图像 1,2 How to Perform a Battery Cycle Reset, Select the procedure: 步骤 7 中的图像 2,2
    • Select the "Battery" icon.
    • Select "Calibrate" to continue.
    • If you want to perform a fingerprint sensor calibration instead, follow this guide.
  8. How to Perform a Battery Cycle Reset: 步骤 8 中的图像 1,3 How to Perform a Battery Cycle Reset: 步骤 8 中的图像 2,3 How to Perform a Battery Cycle Reset: 步骤 8 中的图像 3,3
    • Select the "Start" button.
    • Select the "Start" button again.
    • Select "Ok" to finalize the battery cycle reset.
    • Wait until the battery cycle reset finishes.
    • You may need to reset your device for battery cycle reset to apply.
终点
16等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
213,670 声望
创作了1,040篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,657篇指南
47指南评论
Thanks for catching that! I fixed the link in the introduction.
Arthur Shi -
I installed the galaxy cal app on an S20 and when opening the app I get a message to try again after getting new version
Pierre-Luc Thibeault - 回复
I have the same. Do you know how to fix this now?
Melanie Herget -
simply change your phone date between 2021 and 2022.
mightnire -
添加评论
浏览统计数据:
过去 24 小时: 95
过去 7 天: 622
过去 30 天: 3,315
总计 107,767
