简介
Use this guide to remove the back cover of the Samsung Galaxy Watch4.
你所需要的
Before starting repairs, take your watch off the charger and power it down.
Remove the watch band.
Use a Tri-point Y000 screwdriver to remove the four 4.0 mm-long screws.
Insert an opening tool into the seam between the back cover and the metal housing.
Twist the opening tool to create a gap.
Lay the watch face down.
Carefully swing open the back cover by folding the back cover to the opposite site of the created gap.
Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
3条评论
the glass broke on the back of my watch 4 and i have managed to get all the shards and seal out without damaging anything, but I am having trouble finding remplacement glass for the sensor in canada
Champy Ton - 回复
It just suddenly turned off and won't turn on it just vibrates in sequences, i don't know what to do.
Salim Juma - 回复
I am having a real tough time unscrewing the screws despite having the right screwdriver. It is like they are stuck on.
