跳转到主内容
How to Open the Samsung Galaxy Watch4
你所需要的
  1. How to Open the Samsung Galaxy Watch4, Power down your Galaxy Watch4: 步骤 1 中的图像 1,1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to Open the Samsung Galaxy Watch4, Unscrew the back cover: 步骤 2 中的图像 1,1
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws.
  3. How to Open the Samsung Galaxy Watch4, Wedge open the back cover: 步骤 3 中的图像 1,2 How to Open the Samsung Galaxy Watch4, Wedge open the back cover: 步骤 3 中的图像 2,2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. How to Open the Samsung Galaxy Watch4, Disconnect the sensor flex cable: 步骤 4 中的图像 1,2 How to Open the Samsung Galaxy Watch4, Disconnect the sensor flex cable: 步骤 4 中的图像 2,2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding the back cover to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. How to Open the Samsung Galaxy Watch4, Remove the back cover: 步骤 5 中的图像 1,1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
结论
另外一个人完成了本指南。
Adriana Zwink
于12/18/19注册
62,531 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
7指南评论
the glass broke on the back of my watch 4 and i have managed to get all the shards and seal out without damaging anything, but I am having trouble finding remplacement glass for the sensor in canada
Champy Ton - 回复
It just suddenly turned off and won't turn on it just vibrates in sequences, i don't know what to do.
Salim Juma - 回复
I am having a real tough time unscrewing the screws despite having the right screwdriver. It is like they are stuck on.
Mishaal Jadunundon - 回复
hello, I replaced the sensor but once I connect the flex cable to the motherboard it just doesn't work.
meaning that the sensor is not working (even no green light on the back) but the wireless charging is working.
I tried to disconnect and reconnect again but still no way to let the sensore work.
is there anything that must be reset softwarewise in order the watch can recognize the sensor?
Or probably the flex cable is not working properly?
thanks in advance
Daniele - 回复
I am having the same exact issue. Did you ever find a solution?
Jasmine -
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 47
过去 30 天: 256
总计 14,171
