跳转到主内容
How to Open the Razer Kishi
你所需要的
  1. How to Open the Razer Kishi, Remove the screws: 步骤 1 中的图像 1,1
    • The opening process is the same on both sides. For simplicity, this guide shows only the right-side opening process. Unscrew whichever side you wish to open and work on.
    • For the right side, remove the five Y0 screws securing the right side of the controller.
    • Four 9.2 mm screws
    • One 7.2 mm screw
    • If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
    • One 7.2 mm screw
  2. How to Open the Razer Kishi, Release the bottom edge clips: 步骤 2 中的图像 1,3 How to Open the Razer Kishi, Release the bottom edge clips: 步骤 2 中的图像 2,3 How to Open the Razer Kishi, Release the bottom edge clips: 步骤 2 中的图像 3,3
    • Both cases are held together by plastic clips.
    • Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
    • With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
  3. How to Open the Razer Kishi, Release the side edge clips: 步骤 3 中的图像 1,2 How to Open the Razer Kishi, Release the side edge clips: 步骤 3 中的图像 2,2
    • Slide the opening pick along the right edge to loosen the plastic clips.
  4. How to Open the Razer Kishi, Release the top edge clips: 步骤 4 中的图像 1,2 How to Open the Razer Kishi, Release the top edge clips: 步骤 4 中的图像 2,2
    • Slide the opening pick along the top edge to loosen the remaining plastic clips.
    • Don't try to remove the top side yet, the case is still connected to the board.
  5. How to Open the Razer Kishi: 步骤 5 中的图像 1,3 How to Open the Razer Kishi: 步骤 5 中的图像 2,3 How to Open the Razer Kishi: 步骤 5 中的图像 3,3
    • Carefully lift the top side and unfold it to the right, like a book.
  6. How to Open the Razer Kishi, Disconnect the interconnect cable: 步骤 6 中的图像 1,3 How to Open the Razer Kishi, Disconnect the interconnect cable: 步骤 6 中的图像 2,3 How to Open the Razer Kishi, Disconnect the interconnect cable: 步骤 6 中的图像 3,3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    • Pull the cable out of the socket.
结论
Opening didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
5等其他人完成本指南。
Adriana Zwink
于12/18/19注册
62,444 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,738篇指南
1指南评论
Is the left side glued? Because I can't separate the left side, as it is sealed shut like it was glued together.
Punkie Spam - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 26
过去 30 天: 82
总计 8,977
