跳转到主内容
加入维修社区 - 创建账户
How to Open Your Logitech M310 Wireless Mouse
你所需要的
  1. How to Open Your Logitech M310 Wireless Mouse, Turn off your mouse: 步骤 1 中的图像 1,1
    • Before starting, flip the power switch on the bottom of your mouse to the left, so it's in the OFF position.
  2. How to Open Your Logitech M310 Wireless Mouse, Remove the battery cover: 步骤 2 中的图像 1,3 How to Open Your Logitech M310 Wireless Mouse, Remove the battery cover: 步骤 2 中的图像 2,3 How to Open Your Logitech M310 Wireless Mouse, Remove the battery cover: 步骤 2 中的图像 3,3
    • Press down on the battery cover with your thumb and slide it away from the mouse to unclip it.
    • Remove the battery cover.
  3. How to Open Your Logitech M310 Wireless Mouse, Remove the battery: 步骤 3 中的图像 1,3 How to Open Your Logitech M310 Wireless Mouse, Remove the battery: 步骤 3 中的图像 2,3 How to Open Your Logitech M310 Wireless Mouse, Remove the battery: 步骤 3 中的图像 3,3
    • Use your fingers to lift the end of the battery and slide it out of its recess.
    • During reassembly, slide the battery in negative (-) end first, as shown on the sticker in the recess.
  4. How to Open Your Logitech M310 Wireless Mouse, Remove the case screws: 步骤 4 中的图像 1,3 How to Open Your Logitech M310 Wireless Mouse, Remove the case screws: 步骤 4 中的图像 2,3 How to Open Your Logitech M310 Wireless Mouse, Remove the case screws: 步骤 4 中的图像 3,3
    • Use a Phillips screwdriver to remove the two 5.5 mm‑long screws securing the two halves of the mouse together.
  5. How to Open Your Logitech M310 Wireless Mouse, Separate the mouse halves: 步骤 5 中的图像 1,3 How to Open Your Logitech M310 Wireless Mouse, Separate the mouse halves: 步骤 5 中的图像 2,3 How to Open Your Logitech M310 Wireless Mouse, Separate the mouse halves: 步骤 5 中的图像 3,3
    • With one hand, hold the top half of the mouse.
    • With your free hand, insert a finger into the battery recess on the bottom half.
    • Pull the bottom half of the mouse away from the top half to unclip and remove it.
    • During reassembly, slide the bottom edge of the mouse into place first, and then squeeze the two shells together to engage all the clips.
结论
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
于09/14/22注册
171,489 声望
创作了1,085篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 40
总计 260
