跳转到主内容
How to Open Your Logitech G502 Hero Mouse
你所需要的
  1. How to Open Your Logitech G502 Hero Mouse, Prepare your mouse for disassembly: 步骤 1 中的图像 1,1
    • Before starting your repair, unplug the mouse.
    • Throughout your repair, it may be helpful to lay your mouse on a soft cloth to stabilize it and prevent damage while you work.
  2. How to Open Your Logitech G502 Hero Mouse, Remove the feet: 步骤 2 中的图像 1,2 How to Open Your Logitech G502 Hero Mouse, Remove the feet: 步骤 2 中的图像 2,2
    • The feet are secured to the bottom of the mouse with adhesive. In order to cleanly remove them, the adhesive needs to be thoroughly heated.
    • Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
  3. How to Open Your Logitech G502 Hero Mouse: 步骤 3 中的图像 1,3 How to Open Your Logitech G502 Hero Mouse: 步骤 3 中的图像 2,3 How to Open Your Logitech G502 Hero Mouse: 步骤 3 中的图像 3,3
    • The feet have two layers—a rubberized one and an adhesive pad underneath.
    • If you're reusing the feet, be very careful not to separate the two layers or damage the feet.
    • Carefully slide the point of a spudger under the large foot near the front of the mouse, making sure it goes under both the foot and its adhesive pad.
    • The foot recesses have a small notch that makes it easier to slide your spudger under.
    • Gently slide the spudger farther under the foot and lift until you can grip the pad with your fingers.
  4. How to Open Your Logitech G502 Hero Mouse: 步骤 4 中的图像 1,3 How to Open Your Logitech G502 Hero Mouse: 步骤 4 中的图像 2,3 How to Open Your Logitech G502 Hero Mouse: 步骤 4 中的图像 3,3
    • Peel up and remove the foot.
    • If the rubber layer separates from its adhesive pad, use the same process to remove the pad.
  5. How to Open Your Logitech G502 Hero Mouse: 步骤 5 中的图像 1,3 How to Open Your Logitech G502 Hero Mouse: 步骤 5 中的图像 2,3 How to Open Your Logitech G502 Hero Mouse: 步骤 5 中的图像 3,3
  6. How to Open Your Logitech G502 Hero Mouse, Reassembly information: 步骤 6 中的图像 1,3 How to Open Your Logitech G502 Hero Mouse, Reassembly information: 步骤 6 中的图像 2,3 How to Open Your Logitech G502 Hero Mouse, Reassembly information: 步骤 6 中的图像 3,3
    • To install a new foot:
    • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
    • Remove the feet from their backing and firmly press them into place.
  7. How to Open Your Logitech G502 Hero Mouse, Open your mouse: 步骤 7 中的图像 1,3 How to Open Your Logitech G502 Hero Mouse, Open your mouse: 步骤 7 中的图像 2,3 How to Open Your Logitech G502 Hero Mouse, Open your mouse: 步骤 7 中的图像 3,3
    • Lift the weight door by its tab and remove it.
    • If you have weights in the compartment, remove them.
  8. How to Open Your Logitech G502 Hero Mouse: 步骤 8 中的图像 1,2 How to Open Your Logitech G502 Hero Mouse: 步骤 8 中的图像 2,2
    • Use a Phillips screwdriver to remove the four 5.5 mm‑long screws securing the bottom shell.
  9. How to Open Your Logitech G502 Hero Mouse: 步骤 9 中的图像 1,3 How to Open Your Logitech G502 Hero Mouse: 步骤 9 中的图像 2,3 How to Open Your Logitech G502 Hero Mouse: 步骤 9 中的图像 3,3
    • Tight plastic clips secure the top and bottom shells. During the next few steps you should feel and hear "clicks" as the clips release.
    • Insert the flat end of a spudger between the top and bottom shells, near the back of the mouse.
    • Twist the spudger to unclip the shells.
  10. How to Open Your Logitech G502 Hero Mouse: 步骤 10 中的图像 1,3 How to Open Your Logitech G502 Hero Mouse: 步骤 10 中的图像 2,3 How to Open Your Logitech G502 Hero Mouse: 步骤 10 中的图像 3,3
    • Insert the flat end of a spudger between the textured edge of the top and bottom shells, near the back of the mouse.
    • Slide the spudger towards the front of the mouse and intermittently twist, stopping near the screw hole.
    • Leave the spudger inserted for the next step.
  11. How to Open Your Logitech G502 Hero Mouse: 步骤 11 中的图像 1,3 How to Open Your Logitech G502 Hero Mouse: 步骤 11 中的图像 2,3 How to Open Your Logitech G502 Hero Mouse: 步骤 11 中的图像 3,3
    • Push the spudger into the mouse and twist to unclip the shells.
  12. How to Open Your Logitech G502 Hero Mouse: 步骤 12 中的图像 1,3 How to Open Your Logitech G502 Hero Mouse: 步骤 12 中的图像 2,3 How to Open Your Logitech G502 Hero Mouse: 步骤 12 中的图像 3,3
    • Slide the spudger towards the thumb rest and push in to unclip the shells.
  13. How to Open Your Logitech G502 Hero Mouse: 步骤 13 中的图像 1,3 How to Open Your Logitech G502 Hero Mouse: 步骤 13 中的图像 2,3 How to Open Your Logitech G502 Hero Mouse: 步骤 13 中的图像 3,3
    • Insert the flat end of a spudger between the top and bottom shells, near the G8 and DPI shift () buttons at the front of the mouse.
    • Pry up with the spudger and push the shells apart to unclip them.
    • Unclipping this part of the mouse is tricky and may take a few tries. Be patient and don't pry too hard, or you may break one of the clips.
  14. How to Open Your Logitech G502 Hero Mouse: 步骤 14 中的图像 1,3 How to Open Your Logitech G502 Hero Mouse: 步骤 14 中的图像 2,3 How to Open Your Logitech G502 Hero Mouse: 步骤 14 中的图像 3,3
    • At this point, the shells should be fully separated. If they're not, repeat the previous unclipping steps with your spudger.
    • Lift the top shell straight up and remove it, making sure the main mouse cable stays attached to the bottom shell.
    • During reassembly, put the top shell back in place and work your way around the perimeter firmly squeezing the shells together to reengage the clips.
结论
5等其他人完成本指南。
Spencer Day
于09/14/22注册
154,898 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
1指南评论
G5 and G4 are bound down and I cannot get them freed up.
Wub “Wubba” Wub - 回复
添加评论
浏览统计数据:
过去 24 小时: 49
过去 7 天: 356
过去 30 天: 1,658
总计 17,573
