跳转到主内容
How to Open Your Apple Watch Ultra
你所需要的
  1. How to Open Your Apple Watch Ultra, Power down your watch: 步骤 1 中的图像 1,2 How to Open Your Apple Watch Ultra, Power down your watch: 步骤 1 中的图像 2,2
    • Drain your watch battery below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Take your watch off the charger and power it down.
    • If your touchscreen is broken and you can't power off the watch, use this alternate method to power it down.
  2. How to Open Your Apple Watch Ultra, Safety details: 步骤 2 中的图像 1,3 How to Open Your Apple Watch Ultra, Safety details: 步骤 2 中的图像 2,3 How to Open Your Apple Watch Ultra, Safety details: 步骤 2 中的图像 3,3
    • Because the gap between the screen assembly and frame is so small, a thin metal tool is needed to pry the screen up. Read the following warnings before you start disassembly:
    • Protect your fingers by keeping them completely clear of the front end of your tool. You can protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the iFlex to slip and cut you, or damage the watch.
    • Wear eye protection. The glass may break, sending pieces flying.
    • Attach or remove the watch bands as needed to provide more control as you make repairs.
  3. How to Open Your Apple Watch Ultra, Soften the screen adhesive: 步骤 3 中的图像 1,1
    • Heat an iOpener and apply it to the screen for two minutes to loosen the adhesive underneath.
    • You can also use a hair dryer, heat gun, or hot plate, but be careful not to overheat the watch—the screen and internal battery are both susceptible to heat damage.
  4. How to Open Your Apple Watch Ultra, Insert the iFlex: 步骤 4 中的图像 1,3 How to Open Your Apple Watch Ultra, Insert the iFlex: 步骤 4 中的图像 2,3 How to Open Your Apple Watch Ultra, Insert the iFlex: 步骤 4 中的图像 3,3
    • Place the tip of an iFlex along the edge opposite the Digital Crown and position it in the seam between the screen and the frame.
    • Press the iFlex firmly straight down into the gap.
    • The gap between the screen and the frame is very small, and it makes inserting the iFlex difficult. Don't force the iFlex in, or you risk damaging the screen. If you're having trouble, apply more heat and try again.
  5. How to Open Your Apple Watch Ultra, Pry up the screen: 步骤 5 中的图像 1,2 How to Open Your Apple Watch Ultra, Pry up the screen: 步骤 5 中的图像 2,2
    • Use the iFlex to pry up the screen.
    • The adhesive requires time and constant force to loosen—it probably won't loosen from the initial pry. Reheat the screen and keep applying constant force until the adhesive loosens.
  6. How to Open Your Apple Watch Ultra, Insert an opening pick: 步骤 6 中的图像 1,3 How to Open Your Apple Watch Ultra, Insert an opening pick: 步骤 6 中的图像 2,3 How to Open Your Apple Watch Ultra, Insert an opening pick: 步骤 6 中的图像 3,3
    • Insert an opening pick in the gap you created between the screen and the frame.
    • Remove the iFlex.
  7. How to Open Your Apple Watch Ultra, Slice the adhesive: 步骤 7 中的图像 1,3 How to Open Your Apple Watch Ultra, Slice the adhesive: 步骤 7 中的图像 2,3 How to Open Your Apple Watch Ultra, Slice the adhesive: 步骤 7 中的图像 3,3
    • Insert the tip of the opening pick less than 2 mm to prevent damaging the antenna pin.
    • Slide the opening pick around the top left corner and along the top edge of the watch to slice the screen adhesive.
  8. How to Open Your Apple Watch Ultra: 步骤 8 中的图像 1,2 How to Open Your Apple Watch Ultra: 步骤 8 中的图像 2,2
    • Slide the opening pick around the top right corner and stop just before the Digital Crown.
  9. How to Open Your Apple Watch Ultra: 步骤 9 中的图像 1,2 How to Open Your Apple Watch Ultra: 步骤 9 中的图像 2,2
    • Insert an opening pick into the seam at the top left corner of the watch.
    • Slide the pick along the Action button edge to slice the adhesive.
  10. How to Open Your Apple Watch Ultra: 步骤 10 中的图像 1,2 How to Open Your Apple Watch Ultra: 步骤 10 中的图像 2,2
    • Slide the opening pick around the bottom left corner and along the bottom edge of the watch to slice the screen adhesive.
  11. How to Open Your Apple Watch Ultra: 步骤 11 中的图像 1,2 How to Open Your Apple Watch Ultra: 步骤 11 中的图像 2,2
    • Slide the opening pick around the bottom right corner and stop before you reach the side button.
  12. How to Open Your Apple Watch Ultra, Lift the screen: 步骤 12 中的图像 1,2 How to Open Your Apple Watch Ultra, Lift the screen: 步骤 12 中的图像 2,2
    • Insert the opening pick between the screen and frame at the opposite edge of the Digital Crown.
    • Pry up the screen until you can get a good grip with your fingers.
    • Don't try to remove the screen all the way yet. It's still connected to the watch body.
  13. How to Open Your Apple Watch Ultra, Swing open the screen: 步骤 13 中的图像 1,3 How to Open Your Apple Watch Ultra, Swing open the screen: 步骤 13 中的图像 2,3 How to Open Your Apple Watch Ultra, Swing open the screen: 步骤 13 中的图像 3,3
    • Be careful not to strain the screen cable when you swing open the screen.
    • Lift the screen up and carefully pull it towards the Digital Crown.
    • Swing the screen open to an upward position.
结论
To reassemble your Apple Watch Ultra, follow these instructions in reverse order.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
3等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
247,503 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 55
过去 30 天: 210
总计 5,888
