跳转到主内容
How to Install a Gusset to Enlarge a Sleeve
你所需要的
  1. How to Install a Gusset to Enlarge a Sleeve, Sleeve: 步骤 1 中的图像 1,3 How to Install a Gusset to Enlarge a Sleeve, Sleeve: 步骤 1 中的图像 2,3 How to Install a Gusset to Enlarge a Sleeve, Sleeve: 步骤 1 中的图像 3,3
    • Use tailor's chalk to mark 4 inches from the seam joining the sleeve to the bodice on the center sleeve seam.
    • Use tailor's chalk to mark 4 inches from the seam joining the sleeve to the bodice on the bodice seam.
  2. How to Install a Gusset to Enlarge a Sleeve: 步骤 2 中的图像 1,2 How to Install a Gusset to Enlarge a Sleeve: 步骤 2 中的图像 2,2
    • Use a seam ripper to remove the center sleeve and bodice seams up to the chalk marks.
    • Be sure to avoid splitting the horizontal seam joining the sleeve itself to the bodice.
    • Turn your garment inside out so the seams are facing towards you.
  3. How to Install a Gusset to Enlarge a Sleeve: 步骤 3 中的图像 1,3 How to Install a Gusset to Enlarge a Sleeve: 步骤 3 中的图像 2,3 How to Install a Gusset to Enlarge a Sleeve: 步骤 3 中的图像 3,3
    • Create a pattern by drawing a diamond that is 4 inches by 3 inches on a piece of paper.
    • Add an additional half inch to each side for seam allowance.
    • Cut out your pattern using scissors.
    • On a piece of similarly-colored fabric, pin your pattern using sewing pins to hold it still on the fabric.
    • Using fabric scissors, cut out a diamond-shaped piece of fabric following the pattern you created. This is your gusset.
  4. How to Install a Gusset to Enlarge a Sleeve: 步骤 4 中的图像 1,3 How to Install a Gusset to Enlarge a Sleeve: 步骤 4 中的图像 2,3 How to Install a Gusset to Enlarge a Sleeve: 步骤 4 中的图像 3,3
    • Line up your gusset against the hole in your garment.
    • The longer sides of the diamond should be pointing towards the cuff of the sleeve and the bodice.
    • Pin your gusset to the garment along the edges of the hole you created earlier.
    • You should pin them together with the edges of the gusset and hole overlapping by about half an inch for seam allowance.
  5. How to Install a Gusset to Enlarge a Sleeve: 步骤 5 中的图像 1,2 How to Install a Gusset to Enlarge a Sleeve: 步骤 5 中的图像 2,2
    • Using a sewing machine or needle and thread, take a quarter-inch stich on one edge of the diamond with a straight stitch.
    • Be sure to remove the pins ahead of your stitch as you move down the edge to avoid damage to your sewing machine.
    • Repeat this step for each of the remaining edges of the diamond.
    • Use sewing scissors to trim excess fabric along the edges past your stitch.
  6. How to Install a Gusset to Enlarge a Sleeve: 步骤 6 中的图像 1,2 How to Install a Gusset to Enlarge a Sleeve: 步骤 6 中的图像 2,2
    • Use a zig-zag stitch to seal the rough edges of the diamond using a sewing machine or needle and thread.
    • Turn your garment inside out again, so the seams are on the inside of the garment.
    • Inspect the gusset to make sure there are no gaps in your seam.
终点
Joseph Meyers
于09/26/21注册
133 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 40
过去 30 天: 140
总计 2,267
