跳转到主内容
How to Force Restart the Samsung Galaxy Watch
  1. How to Force Restart the Samsung Galaxy Watch, How to Force Restart the Samsung Galaxy Watch: 步骤 1 中的图像 1,1
    • Push and hold the lower button for at least 7 seconds.
    • Let go of the button when you see the watch restart.
    My smart watch got problem with cant power on
    kok chua - 回复
    me too. I have charged and tried to restart by power button down but hasn't come back on. Any other ideas?
    PJ Cav - 回复
    Hola, si mantenéis pulsado el botón de encendido hasta que salga rebooting. En ese momento pulsar repetidamente el botón de encendido hasta que salga la opción de recovery y pulsais nuevamente el boton de encendido 1 o 2 segundos para seleccionarlo.
    Fernando Rivero - 回复
    J'ai réinitialiser ma montre touche retour en arrière ne fonctionne pas
    NADIR BENMAMAR - 回复
终点
5等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
117,781 声望
创作了188篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,083篇指南
11条评论
If I have done the hold button 7 seconds & it still dont come on then what?
Tracy L - 回复
That's what I want to know also
paullawrence657 - 回复
Me too. My watch won't come on either.
Sheri Hall Lee - 回复
I suppose all commenters above have tried to charge the watch over night to make sure the battery is not completely depleted.
You could try and restart WHILE it is charging or even just placed on the charger without being plugged into the wall.
Tobias Isakeit - 回复
I dropped my watch off the counter and it's just keeps showing rebooting it won't let me restart watch or activate it from my phone.
Bailey Nasuta - 回复
Did you check if maybe the button is stuck and forces it to restart?
Tobias Isakeit -
Thanks very much!
Judith Durkin - 回复
I've tried multiple rebooting techniques and none have worked, I also went into galaxy wearable app on phone to reset but it won't let me into general settings to do reset, the app also tells me it's not connected but how am I to connect if it don't turn on?
J LETICIA - 回复
im having the exact same issues, nothing is working
Vince Blagdon - 回复
Mine is having the same issue. After swimming it did not shut off the water mode, no matter what. Tried to reset it but the power button did not work. Have opened it to look inside and try to find something easy to fix but it´s hard to find the faulty part/component. So, without knowing which spare part to buy and replace it I guess it´s end of game for this piece of hardware. Not worth it taking to servicing since spare parts for this 5 years old watch are not easily available and/or might be as expensive as new watch.
zapata el loko - 回复
Not restart my watch
Ganesh Chettri - 回复
添加评论
浏览统计数据:
过去 24 小时: 27
过去 7 天: 188
过去 30 天: 720
总计 37,507
