跳转到主内容
加入维修社区 - 创建账户
How to Fix a Car Dent
你所需要的
  1. How to Fix a Car Dent, How to Fix a Car Dent: 步骤 1 中的图像 1,2 How to Fix a Car Dent, How to Fix a Car Dent: 步骤 1 中的图像 2,2
    • Be sure that the bucket or pot is big enough to fit the vacuum that will be used for this procedure
    • It is suggested when cutting a hole into the bottom of the bucket, you use a Utility Knife and not rush through this step
    • The use of a Utility Knife over a normal knife makes it safer for everyone, and gives a more precise cut
    询问修复机器人
    添加评论
  2. How to Fix a Car Dent: 步骤 2 中的图像 1,1
    • Insert the vacuum into the hole at the bottom of the bucket to be sure it fits
    • If the hole is too small and the vacuum cannot fit within the hole, go back to step one and attempt to enlarge the hole
    • If the hole appears to be too large, one may want to consider going back to step one with a new bucket
    询问修复机器人
    添加评论
  3. How to Fix a Car Dent: 步骤 3 中的图像 1,1
    • Be sure to wipe down the area that will be worked on with a dry cotton rag
    • The dirt and oil that may be on the surface of your car can make it harder to complete the steps that follow. Due to the fact that dirt and oil can cause issues with the effectiveness of how tape may stick.
    询问修复机器人
    添加评论
  4. How to Fix a Car Dent: 步骤 4 中的图像 1,3 How to Fix a Car Dent: 步骤 4 中的图像 2,3 How to Fix a Car Dent: 步骤 4 中的图像 3,3
    • Place the bucket over the dent that needs to be fixed
    • Start by lightly taping down the bucket with painters tape - this allows the bucket to be held up and allow the rest of the tapping easier to do
    • Go over the edges of the bucket with duct tape until you are sure that it is airtight onto the car
    询问修复机器人
    添加评论
  5. How to Fix a Car Dent: 步骤 5 中的图像 1,1
    • Place the vacuum into the hole at the bottom of the bucket
    • At this point be sure to allow some time for suction to occur and listen for a small popping noise
    • The popping noise that needs to be listened for is the dent in your car popping out from the suction of the vacuum
    询问修复机器人
    添加评论
  6. How to Fix a Car Dent: 步骤 6 中的图像 1,1
    • At times the way the vacuum is positioned can affect the suction
    • If after some time there is no popping noise, adjusting the placement of the vacuum is recommended
    • After adjusting the vacuum allow time for suction again and listen for a popping noise to know when your dent is fixed
    添加评论
终点
取消:我没有完成这个指南。
7等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 35
过去 30 天: 196
总计 8,033
