跳转到主内容
How to Fix a Broken XLR Microphone Cable
你所需要的
  1. How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: 步骤 1 中的图像 1,3 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: 步骤 1 中的图像 2,3 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: 步骤 1 中的图像 3,3
    • This guide will utilize a soldering iron. Please use a heat-resistant surface and proceed with caution.
    • Place the end of the XLR Cable on a clean, uncluttered surface.
    • Using a small screwdriver, unscrew the single screw near the top of the cable.
    • Gently pull apart the exterior metal from the internal mechanism.
  2. How to Fix a Broken XLR Microphone Cable: 步骤 2 中的图像 1,1
    • Assess which connections have fallen loose. In this instance, the white cable is disconnected.
  3. How to Fix a Broken XLR Microphone Cable: 步骤 3 中的图像 1,2 How to Fix a Broken XLR Microphone Cable: 步骤 3 中的图像 2,2
    • Assess whether or not there's enough exposed wire to reconnect loose cables. In this instance, the exposed cables are too short to effectively reconnect.
    • If the exposed wires are too short, use wire strippers or a razor to cut back the insulation.
    • Separate the wires.
  4. How to Fix a Broken XLR Microphone Cable: 步骤 4 中的图像 1,3 How to Fix a Broken XLR Microphone Cable: 步骤 4 中的图像 2,3 How to Fix a Broken XLR Microphone Cable: 步骤 4 中的图像 3,3
    • Soldering irons are extremely hot. Proceed with extreme caution.
    • Solder each of the loose wires to the coinciding metal prong.
    • For more information on effectively soldering wire, please visit iFixit's Soldering Guide.
    • If necessary, use a thin wire to further manipulate the connection.
  5. How to Fix a Broken XLR Microphone Cable: 步骤 5 中的图像 1,2 How to Fix a Broken XLR Microphone Cable: 步骤 5 中的图像 2,2
    • When the soldering is complete, reconnect the metal exterior to the head of the cable.
    • Using a small screwdriver, reattach the single screw.
结论
4等其他人完成本指南。
Abbie Zajac
于01/19/16注册
203 声望
撰写一个指南
团队
1指南评论
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
DIM Tips - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 93
总计 27,043
